914/6 oil tank- how to drain? |
rfuerst911sc |
Nov 27 2007, 05:02 AM
Advanced Member Group: Members Posts: 2,158 Joined: 4-May 06 From: Dahlonega , Georgia Member No.: 5,980 Region Association: South East States |
I have purchased a DW Design oil tank for my /6 conversion. If I understand the way the OEM/aftermarket tanks are made they do not have a drain plug like a 911 tank has. So if that is true how do you drain the tank when doing oil changes? Do you have to disconnect an oil line? That sounds like a stupid way to do it. What about installing a "T" at the bottom fitting of the tank so the one open side can be capped? Any other way to do it? Thanks
Nick |
Nov 27 2007, 05:50 AM
Member Group: Members Posts: 144 Joined: 25-June 04 From: Washington DC Member No.: 2,250 |
I have a T fitting. One of the three outlets from the T fitting is capped. I use that to drain the oil. Just be ready when you take the cap off cause the oil comes out fast.
Nick |
Root_Werks |
Nov 27 2007, 08:11 AM
Village Idiot Group: Members Posts: 8,331 Joined: 25-May 04 From: About 5NM from Canada Member No.: 2,105 Region Association: Pacific Northwest |
I have a T fitting. One of the three outlets from the T fitting is capped. I use that to drain the oil. Just be ready when you take the cap off cause the oil comes out fast. Nick (IMG:style_emoticons/default/agree.gif) Same thing I did and use. Works great and yeah, oil will come out fast. |
thesey914 |
Nov 27 2007, 08:30 AM
Senior Member Group: Benefactors Posts: 1,155 Joined: 1-January 03 From: Staffordshire -England Member No.: 66 |
Any chance of a picture of the 'Tee' piece.
Mike Knox |
Nov 27 2007, 10:25 PM
MikeTuba Group: Members Posts: 158 Joined: 17-October 03 From: Ashland, OR Member No.: 1,258 Region Association: Pacific Northwest |
Dr Evil |
Nov 27 2007, 11:30 PM
Send me your transmission! Group: Members Posts: 23,002 Joined: 21-November 03 From: Loveland, OH 45140 Member No.: 1,372 Region Association: MidAtlantic Region |
I find it easy enough to split the lines between the two using the special wrench. Its not too messy after using the engines drain plug.....but I am poorer than many of you (IMG:style_emoticons/default/wink.gif)
Nice set up, Mike! |
thesey914 |
Nov 28 2007, 02:50 AM
Is that a hydraulic clutch??
Lo-Fi Version | Time is now: 31st May 2024 - 11:48 PM |
