Djet mix and match question, Can this work? |
r_towle |
Dec 20 2007, 02:39 PM
Custom Member Group: Members Posts: 24,591 Joined: 9-January 03 From: Taxachusetts Member No.: 124 Region Association: North East States |
Hi,
I have a restored plenum, runners, rubbers, Throttle body, and air cleaner for a 2.0 liter. I have a 1.7 liter motor. Can I swap just those parts? Assume I will keep the MPS, the injectors, all the sensors etc, just bolt on the new setup. Will it fit? plenum/runners? Will it make the car run to lean? more air flow... BTW, she runs nice and rich now anyways. Rich |
ejm |
Dec 20 2007, 03:03 PM
I can see the light at the end of the tunnel Group: Members Posts: 2,694 Joined: 3-February 03 From: Massachusetts Member No.: 224 Region Association: None |
2.0 has three studs for the intake and the 1.7 has four
type47 |
Dec 20 2007, 03:48 PM
Viermeister Group: Members Posts: 4,254 Joined: 7-August 03 From: Vienna, VA Member No.: 994 Region Association: MidAtlantic Region |
(IMG:style_emoticons/default/agree.gif) if you are running rich, i'd find the reason for that and not try to band-aid by greater air flow, IMO. 1.7 intake runners are different size than the intake phlenum so you would want a set of 1.8 intake runners (4 bolts to head) to match the 2.0 intake air distributor.
r_towle |
Dec 20 2007, 05:27 PM
r_towle |
Dec 20 2007, 05:30 PM
(IMG:style_emoticons/default/agree.gif) if you are running rich, i'd find the reason for that and not try to band-aid by greater air flow, IMO. 1.7 intake runners are different size than the intake phlenum so you would want a set of 1.8 intake runners (4 bolts to head) to match the 2.0 intake air distributor. I can drill the runners. the 1.7 runs rich by design, its not by much. Its all tuned up. I really need a cheap paper air filter setup for a 1.7. If not, Ihave fixed all this stuff up for a future 2.0 and its all pretty. I figured with a few hours, I have a nice setup. Or, I go put the old oil bath setup back on...which might happen. She is being brought into service for the next 4 weeks due to two boys coming home and needing cars. Rich |
orange914 |
Dec 20 2007, 07:08 PM
http://5starmediaworks.com/index.html Group: Members Posts: 3,371 Joined: 26-March 05 From: Ceres, California Member No.: 3,818 Region Association: Northern California |
Hi, I have a restored plenum, runners, rubbers, Throttle body, and air cleaner for a 2.0 liter. I have a 1.7 liter motor. Can I swap just those parts? Assume I will keep the MPS, the injectors, all the sensors etc, just bolt on the new setup. Will it fit? plenum/runners? Will it make the car run to lean? more air flow... BTW, she runs nice and rich now anyways. Rich after all that work it may not gain anything with the constipated 1.7 exhaust system. my understanding is it already dampens any air/fuel input improvements. i wonder if those conditions would cause excwssive heated engine mike |
Lo-Fi Version | Time is now: 9th June 2024 - 03:52 PM |
