Howie's 914 |
Member ![]() ![]() Group: Members Posts: 76 Joined: 29-June 04 From: Greensboro, NC Member No.: 2,273 ![]() |
Ok, so my baby has come home. (IMG:style_emoticons/default/idea.gif) I am thinking about rewiring the car with a new aftermarker 18 circuit system. The wires I took out I would not put back. I am also going from a 4 to a 6 so I will not be needing the EFI. Please let me know if anyone has done this and if so any tips and pic's would be great.
Cap'n Krusty |
Cap'n Krusty ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 10,794 Joined: 24-June 04 From: Santa Maria, CA Member No.: 2,246 Region Association: Central California ![]() |
Right off the bat, there aren't any FI related wires in the main harness, other than maybe the wires for the fuel pump. Secondly, the wiring in a 914 is pretty well organized, non-redundant, and well thought out. The fuses aren't asked to carry anywhere near the load they can, and any shared circuits supply related consumers. Unless the wiring is rat-eaten, burned, scraped through, or hacked by a person of less skill than is required to do the job properly, I've rarely had to replace any of it (and I'm coming up on 35 years of working on 914s on a near daily basis). The Cap'n
Howie's 914 |
Thanks. The problem is alot of the wires have lost the plastic covering.
LvSteveH |
I put the Poor in Porsche ![]() ![]() ![]() Group: Members Posts: 1,080 Joined: 22-April 03 From: Las Vegas, Nevada Member No.: 600 ![]() |
I recently did a complete rewire using an American Autowire highway 22 kit on one of my cars.
It's a really big job, especially if you want to use all the factory switches and accessories. On the up side it uses modern GXL wire which is a huge improvement over the original wires. The fuse panel I used is a little large, but it is way more than would ever be needed. By the time you're done you'll have a really thorough understanding of how everything works and the satisfaction of doing it yourself. You could of course just make a carbon copy of the factory harness using new wire, but I think it makes a lot more sense to source a nice used harness if you plan on going that route. As Mr. Krusty said, as long as they are properly wired up the factory setup is pretty reliable. I usually install a supplemental relay and wires for the headlights, but otherwise haven't had too many issues. |
degreeoff |
I like big butts and I can not lie! ![]() ![]() ![]() Group: Members Posts: 1,622 Joined: 9-February 03 From: Booowieeee MD (near DC) Member No.: 275 Region Association: MidAtlantic Region ![]() |
yep EZ wiring 12 kit. I only did the basics and had to modify it a bit for the 'mid' engine config....but I think it'll work!!! (ignition, lights, signals, brakes, gauges and wipers) see my thread for ppics...to detailed to explain it all but the folks over there @ EZ were very helpful I being ANAL as I am even used heat shrink tubing on it ALL what a PIA!!
Bartlett 914 |
Advanced Member ![]() ![]() ![]() ![]() Group: Members Posts: 2,218 Joined: 30-August 05 From: South Elgin IL Member No.: 4,707 Region Association: Upper MidWest ![]() |
If your wiring is trashed, I would suggest getting one from a parts car. There should be plenty around. If you need a new fuse panel. Engman sells a nice one.
Lo-Fi Version | Time is now: 15th July 2025 - 03:52 AM |
