> rear number (licence) plate lights, hardware
thesey914
post Jan 16 2008, 01:55 PM
Hello, can anyone tell me the type of screw required to mount the (early) lights? Self tapper or is it a bolt?
thanks in advance
Cap'n Krusty
post Jan 16 2008, 02:36 PM
Cap'n Krusty
They're small sheet metal screws. The Cap'n
thesey914
post Jan 16 2008, 04:59 PM
Are they found anywhere else on a 914
So.Cal.914
post Jan 16 2008, 05:10 PM
"...And it has a front trunk too."
QUOTE(thesey914 @ Jan 16 2008, 02:59 PM) *
Boy...Maybe, but I can't think of one off hand.
Larry.Hubby
post Jan 17 2008, 01:30 AM
Member who doesn't post much, but has a long time in 914s
They're 3.5x16mm sheet metal screws. Screws of the same description are used to hold down the aluminum strips that secure the carpet on the sills (the heads on these may be a slightly different shape, but the diameter and pitch are the same), and shorter ones (9.5mm) are used to hold on the padding on the A-pillar and above the windshield. 3.5mm metric sheet metal screws are almost the same size as the US #6 screws, and I've found that #6x3/4" screws you can get at any hardware store work just as well as the correct metric parts.
Larry
So.Cal.914
post Jan 17 2008, 01:44 AM
QUOTE(Larry Hubby @ Jan 16 2008, 11:30 PM) *
Larry
Larry, aren't those more of a flat head (slightly rounded counter sunk) and the one's for the LPL are panheads...Right?
TINCAN914
post Jan 17 2008, 06:34 AM
Summer's Commin...
Sorry for the high jack, but I was trying to figure mine out several months ago. Can anyone tell me where the wires from the ligth hooks up to? If I remember correctly I ran them to the running lights but I was burning fuses.
Dave_Darling
post Jan 17 2008, 10:11 AM
914 Idiot
Tincan, look carefully at the light. You'll see that one of the lugs for the wires has some metal that also goes to one of the mounting screw holes. That's the lug you use for the ground (brown) wire. The other gets the power (grey?) wire.
--DD
TINCAN914
post Jan 17 2008, 11:56 AM
Summer's Commin...
Thanks Dave, but where do I get the power from? I thought off the running lights directly from the rear tail lights?
So.Cal.914
post Jan 17 2008, 01:06 PM
There are wires for those lights in the loom that run across the back, from drivers side to pass side of the trunk.
Dave_Darling
post Jan 17 2008, 09:48 PM
914 Idiot
Yup, they're there. They hook into the wires that light up the engine compartment light, which in turn hooks into the wires that power the center console instrument lights (on a 74+ car at least).
--DD
Larry.Hubby
post Jan 18 2008, 01:13 AM
Paul,
Yes, you're right. The LPL screws are what Porsche calls "lens head", which is similar to our pan head, while the carpet strip and trim-securing screws are oval headed, which is like a flathead but with a slightly convex top.
Larry
- Lo-Fi Version Time is now: 6th July 2025 - 12:18 PM
