Rear Brakes, From '70 911 |
ninepfourteen |
Jan 17 2008, 06:24 PM
Member Group: Members Posts: 70 Joined: 19-March 04 From: western, MD Member No.: 1,820 |
Will rear calipers from a 70 911 work on the rear of a 914 and allow vented rotors?
Thanks. |
Cap'n Krusty |
Jan 17 2008, 06:28 PM
Whether they'll fit or not, you won't have a handbrake without pretty extensive modifications. It's illegal in every state to operate a motor vehicle without a parking brake on the street , in case you care. The Cap'n
davep |
Jan 17 2008, 07:06 PM
914 Historian Group: Benefactors Posts: 5,151 Joined: 13-October 03 From: Burford, ON, N0E 1A0 Member No.: 1,244 Region Association: Canada |
If you care to use the search function you will find extensive discussion on the requirements of caliper fitment. I completely agree with The Cap'n, that operating a vehicle without a FUNCTIONING handbrake is illegal pretty much everywhere on this and most every continent. The handbrake is there to act as a failsafe in the event of primary (hydraulic) brake failure, and MUST be in working condition. Acting as a parking brake, by means of the ratchet mechanism, is considered an additional bonus.
Eric_Shea |
Jan 18 2008, 01:06 AM
PMB Performance Group: Admin Posts: 19,278 Joined: 3-September 03 From: Salt Lake City, UT Member No.: 1,110 Region Association: Rocky Mountains |
Yes, with 5mm spacers under the mounting ears.
1. What will you do for a handbrake? 2. What will you do to balance out your front to rear bias? |
ninepfourteen |
Jan 18 2008, 05:11 AM
1) It's a race car. It has no E brake now.
It has a dial bias valve now and I'm going to 944T fronts at the same time. I want to get rid of the rear adjusters that we have to mess with constantly. Thought I'd go vented at the same time. Eric, I need to put the 5 mm under the ears, not the rotors? Thanks. Fred Yes, with 5mm spacers under the mounting ears. 1. What will you do for a handbrake? 2. What will you do to balance out your front to rear bias? |
Eric_Shea |
Jan 18 2008, 11:46 PM
QUOTE Eric, I need to put the 5 mm under the ears, not the rotors? One or the other (IMG:style_emoticons/default/wink.gif) |
Lo-Fi Version | Time is now: 3rd June 2024 - 12:26 AM |
