Stalling, Possible electrical mimic |
redshift |
Jan 7 2004, 08:17 AM
Bless the Hell out of you! Group: Members Posts: 10,926 Joined: 29-June 03 Member No.: 869 |
My car still stalls, did it twice last night.
It flutters all of a sudden at idle, and falls off instantly dead. It starts hard after that, sometimes taking a couple minutes. When it's failing, I smell plenty of gas. (IMG:style_emoticons/default/smile.gif) The lights remain bright, not a global electrical puzzle. This happens warm, not a specific heat range that I know of, I could not get the CHT to fail on a meter, 4 trys, thru 45 minutes of cooling. I don't think it's the trouble. Any thoughts. Temporary ignition system failure? How can I safely check. Thanks. M |
redshift |
Jan 7 2004, 08:23 AM
In case...
Euro 2.0 Djet stock plugs look nice everything is clean and grounded (IGNITION SYSTEM NOT CHECKED) continuity across the harness as far as I can tell (checked) CHT appears in working order Fuel system appears to be in fine order |
redshift |
Jan 7 2004, 07:37 PM
Still haven't found anything to fix.
I had hair when I bought this car, one of them is going to be leaving this place very soon. (IMG:style_emoticons/default/smile.gif) Good thing I am a laid back individual. M |
eldiosyeldiablo |
Jan 7 2004, 07:55 PM
Member Group: Members Posts: 129 Joined: 19-August 03 From: Roswell, GA Member No.: 1,047 |
Hey Red where are you located at? I saw one of your other postings say something about the Savanah river.
redshift |
Jan 7 2004, 08:14 PM
Yeah man, I am in (IMG:style_emoticons/default/clover.gif) Savannah. I'm originally from Augusta, I can't get away from this river, hence the atomic (IMG:style_emoticons/default/nuke.gif) green bile that spews forth from whence I go.
I hate it here. M |
redshift |
Jan 7 2004, 08:22 PM
I think my stalling trouble must be in the ignition, anyone want to argue that?
(IMG:style_emoticons/default/smile.gif) As long as I catch it wobbling and about to die, it just requires little throttle taps to keep it running... but it seems like the combustion just collapses.. plenty of gas, cause that bad boy floods trying to start *if* it does die. M |
redshift |
Jan 7 2004, 10:10 PM
Ok! Nobody knows..
(IMG:style_emoticons/default/smile.gif) It runs like a hot monkey to a frozen jockstrap... just the stalling for no apparent reason.. Lie to me! M |
JeffBowlsby |
Jan 7 2004, 11:42 PM
914 Wiring Harnesses Group: Members Posts: 8,551 Joined: 7-January 03 From: San Ramon CA Member No.: 104 Region Association: None |
If its too rich...
Erratically leaking injector or CSV? Failing dizzy weights? Bad ECU? |
redshift |
Jan 7 2004, 11:46 PM
I have the factory manuals, but I don't really understand what I am looking at, I think it's the black and white pictures.. (IMG:style_emoticons/default/smile.gif)
I am hoping it's in the points, or other ignition related parts, for my sanity. I need to know what to check when it happens... I can't tell when that will be. Advice? M |
Bruce Allert |
Jan 8 2004, 12:11 AM
Hellions asleep Group: Members Posts: 3,289 Joined: 19-March 03 From: Eagle Creek, Orygun Member No.: 441 Region Association: Pacific Northwest |
2 things came to mind while reading the thread at the beginning & then I got down to Bowlsbys answer. His were what I was thinking also... the CSV or a leaky inj. I had a problem that sounds like this so I pulled the injectors & cleaned them. Also pulled the CSV & did the same. Don't know which was the culprit but one of them was (IMG:style_emoticons/default/beer.gif) Later I installed Pertronix, CHT and TPS which really made a world of difference (IMG:style_emoticons/default/smile.gif)
..........b |
ChrisReale |
Jan 8 2004, 12:33 AM
Sleazy Group: Members Posts: 2,665 Joined: 20-January 03 From: San Francisco Member No.: 176 |
Miles, go to ebay, and win this auction. might help your car and you understand one another.
edit: I deleated it because it was pretty gross |
redshift |
Jan 8 2004, 12:37 AM
I am going to do some new things in the morning, I hope I can run this down, it's annoying.
Thanks guys, as always, except you, Chris. M |
ChrisReale |
Jan 8 2004, 12:41 AM
QUOTE(redshift @ Jan 7 2004, 10:37 PM) Thanks guys, as always, except you, Chris. Remember, (IMG:http://www.engrish.com/image/engrish/wintergnats.jpg) |
redshift |
Jan 8 2004, 01:16 AM
Looks like a Sprite flavored tampon commercial.
M |
Jeffs9146 |
Jan 8 2004, 10:06 AM
Ski Bum Group: Members Posts: 4,062 Joined: 10-January 03 From: Discovery Bay, Ca Member No.: 128 |
Is it a 2.0? Check the head temp sensor!?
Jeff |
redshift |
Jan 8 2004, 12:45 PM
I did, I can't get it to fail on a meter.
I do know how to get a ragin' backache from leaning into the engine bay! (IMG:style_emoticons/default/smile.gif) M |
Lo-Fi Version | Time is now: 18th June 2024 - 01:20 PM |
