degreeoff |
I like big butts and I can not lie! ![]() ![]() ![]() Group: Members Posts: 1,622 Joined: 9-February 03 From: Booowieeee MD (near DC) Member No.: 275 Region Association: MidAtlantic Region ![]() |
Ok I am in need of a little direction here guys. I am doing a 914-6 conversion and I am down to wiring the ALT....I know where the wires from my 914-4 alt go but am confused as to where the 911 ALT wires go. I have attached 2 pictures to show what I have to work with.....
1st question is on the 911 ALT have I got the poles listed correctly? and... 2nd question is do I split the (blue/D+/61) wire to go to the idiot light and my voltage regulator? 3d question is the 2nd red wire (the smaller one) that is not on my 914-4? Do I just disregard this wire? I hope this makes sense... Thank You Josh (the nearly done one) ![]() ![]() |
SLITS |
"This Utah shit is HARSH!" ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Benefactors Posts: 13,602 Joined: 22-February 04 From: SoCal Mountains ... Member No.: 1,696 Region Association: None ![]() ![]() |
As I remember, just follow the same colors and same wires on the /4 3 prong connector .... that's if you are using a /4 relay board .... which is what I did.
Other wise I will have to check my wiring when I get to the shop in an hour and report back tonight. The small red wire (in the /6 loom) is always hot and I left it unconnected on my /6 conversion (ok, I capped it but didn't connect it to anything). |
degreeoff |
OK so I am #'d correctly? Black is equal to the DF?
effutuo101 |
Advanced Member ![]() ![]() ![]() ![]() Group: Members Posts: 2,736 Joined: 10-April 05 From: Lemon Grove Member No.: 3,914 Region Association: Southern California ![]() |
From the first picture, yes. There is a DF on the plate ( unless it is on upside down) where the black wire is attached.
Lo-Fi Version | Time is now: 31st July 2025 - 08:54 PM |
