Stock flywheel weight |
yarin |
Feb 29 2008, 04:20 PM
'14-X'in FOOL Group: Members Posts: 988 Joined: 13-May 03 From: Guttenberg, NJ Member No.: 693 Region Association: North East States |
Does anyone know what a stock 2.0L flywheel weighs?
thx |
toon1 |
Feb 29 2008, 04:59 PM
Senior Member Group: Members Posts: 1,849 Joined: 29-October 05 From: tracy,ca Member No.: 5,022 |
I thought I remember it being about 14lbs.
yarin |
Mar 3 2008, 09:38 PM
Can anyone confirm? I just bought one on ebay, guy claimed it was lightened to 13.5 lbs?? find that rather hard to believe if the stock weights close to 14lbs..
gregrobbins |
Mar 3 2008, 09:56 PM
Member: Team NARP Group: Members Posts: 1,515 Joined: 23-March 04 From: Arizona Member No.: 1,844 Region Association: Southwest Region |
17 to 19Lbs? 13.5 should be pretty good for a street motor. I've heard that track motors you want 9 to 12 lb flywheels.
So.Cal.914 |
Mar 4 2008, 12:30 AM
"...And it has a front trunk too." Group: Members Posts: 6,588 Joined: 15-February 04 From: Low Desert, CA./ Hills of N.J. Member No.: 1,658 Region Association: None |
I run a 13 lb on mine, I like it. It cut any added weight from the counterbalanced
crank and then some. Rev's nice and quick, good deceleration. |
sww914 |
Mar 4 2008, 01:12 AM
Advanced Member Group: Members Posts: 2,439 Joined: 4-June 06 Member No.: 6,146 Region Association: None |
My feeble memory says 17#. My memory is as about as reliable as a weather forecast, but I still think I'm as right as the meteorologist does.
The lightened one in my car is 7#. It rev's up and down quickly, but it barely idles. I don't care, I only care abut how it runs at full throttle over 4000 RPM's. |
yarin |
Mar 4 2008, 06:38 PM
OK good. I actually just bought two flywheels, one that weighs 7lbs. and one that weighs 13.5 lbs. I do occasionally drive on the street, so from what i've read I'm paranoid that going with a 7lb flywheel is going to lead to problems with the crank/fan/shearing bolts, etc etc. Is this really a concern? I use the car for autox, put maybe 500 street miles on it a year. Can I risk damaging the motor running a 7lb flywheel?
Also - I don't plan on tearing down the motor yet, but if I want mount either flywheel, should I have it balanced with the clutch/PP off the car? Don't want any bad vibrations... Thanks |
TheMirror |
Jun 18 2009, 12:45 AM
Newbie Group: Members Posts: 16 Joined: 22-January 09 From: NorCal Member No.: 9,962 Region Association: None |
Jake Raby |
Jun 18 2009, 02:10 AM
Engine Surgeon Group: Members Posts: 9,394 Joined: 31-August 03 From: Lost Member No.: 1,095 Region Association: South East States |
That 15.3 must have been resurfaced.. 16.5 is the stock non resurfaced weight.
I just weighed one. |
BMXerror |
Jun 18 2009, 06:44 PM
Senior Member Group: Members Posts: 1,705 Joined: 8-April 06 From: Hesperia Ca Member No.: 5,842 |
I don't know if there's a difference in the 1.7/2.0 flywheels. I cut my 1.7 wheel down, though, and it works great at 12 pounds, even around the street. With a car as light as the 914, there's no need for a really heavy flywheel. BTW, my flywheel was 17ish before being turned.
Mark D. |
TravisNeff |
Jun 19 2009, 10:10 PM
914 Guru Group: Members Posts: 5,082 Joined: 20-March 03 From: Mesa, AZ Member No.: 447 Region Association: Southwest Region |
same flywheel is used for 1.7, 1.8 & 2.0, AFAIK
Lo-Fi Version | Time is now: 8th June 2024 - 08:46 AM |
