What's the difference between..., Narrow band and Wide Band O2 Sensors? |
BMXerror |
Mar 16 2008, 06:12 PM
Senior Member Group: Members Posts: 1,705 Joined: 8-April 06 From: Hesperia Ca Member No.: 5,842 |
Well? Anybody know what the difference is beside hundreds of dollars? Thanks to all who are more knowledgeable than me.
Mark D. |
SirAndy |
Mar 16 2008, 07:57 PM
Resident German Group: Admin Posts: 41,651 Joined: 21-January 03 From: Oakland, Kalifornia Member No.: 179 Region Association: Northern California |
Well? Anybody know what the difference is beside hundreds of dollars? Thanks to all who are more knowledgeable than me. if i'm not mistaken, it's the resolution of the signal ... (IMG:style_emoticons/default/beerchug.gif) Andy |
Rick_Eberle |
Mar 16 2008, 08:18 PM
Member Group: Members Posts: 390 Joined: 14-January 04 From: Geelong, Australia Member No.: 1,558 |
The narrowband pretty much just tells you whether you are above or below stoich (14.7:1 AFR).
A wide band give a continuous range, usually from roughly 10:1 to 20:1. |
Dave_Darling |
Mar 16 2008, 09:09 PM
914 Idiot Group: Members Posts: 14,990 Joined: 9-January 03 From: Silicon Valley / Kailua-Kona Member No.: 121 Region Association: Northern California |
The NBO2 tells you just barely enough info to keep a catalytic converter happy. It can tell you if you're richer or leaner than 14.7:1, but not how much. (Yeah, the gauges read in numbers, but they're lying.) You can use this to make small adjustments on-the-fly to keep the catalyst in its best operating zone. That's how OEMs use it.
The WBO2 tells you what your mixture actually is. You can actually use this one to tune with. --DD |
chris914 |
Mar 16 2008, 09:47 PM
Member Group: Members Posts: 489 Joined: 24-July 04 From: San Diego, CA Member No.: 2,393 Region Association: Southern California |
Here are some videos that explains the Narrow band and Wide Band O2 Sensors.
"LM-101: Tuning Basics, Theory, and Applications" http://www.innovatemotorsports.com/resources/lm101.php |
Lo-Fi Version | Time is now: 23rd May 2024 - 06:33 AM |
