Installing Rear Stabilizer Bar, Factory Mounting rear Stabilizer Bar |
HillKing |
Mar 18 2008, 01:34 PM
Self taught incompetent Group: Members Posts: 62 Joined: 11-January 08 From: Cody, Wyoming Member No.: 8,563 Region Association: None |
I have a factory supplied rear stabilizer bar for HillKing. My question is has anyone out there installed one of these into a car that did not have one from factory? Looking at the Stoddard book they show a 914.507.027.10 "securing plate" for 75-76 year car and a 914.501.259.11GVR for 73-74 cars. They also show part 914.501.532.71 reinforcement for both securing plates. Pelican shows this in their diagrams as well. Looking at the car there appears to already be holes for the bolt up stamped in the sheetmetal under the trunk crossbrace. So it looks as if the securing plate goes into the void between the upper engine compartment sheet metal and the trunk cross brace. Do you have to cut out on the topside to mount the securing plate and I assume the "reinforcement" would weld on after? Anybody using this setup?
davep |
Mar 18 2008, 02:39 PM
914 Historian Group: Benefactors Posts: 5,151 Joined: 13-October 03 From: Burford, ON, N0E 1A0 Member No.: 1,244 Region Association: Canada |
It should be just a simple welding job on both sides of the trunk floor.
SirAndy |
Mar 18 2008, 06:43 PM
Resident German Group: Admin Posts: 41,669 Joined: 21-January 03 From: Oakland, Kalifornia Member No.: 179 Region Association: Northern California |
the reinforcement plates go inside the rear trunk. they add strength to the mounts:
then clean up the underside and weld in the mounting brackets: (IMG:style_emoticons/default/bye1.gif) Andy PS: i used the bar and clamps as a guide to where exactly place the mounting brackets. i made sure both clamps where at the same spot left/right on the bar and then centered those and tacked in the brackets. double checked and then did the final welding. the reinforcement on the inside of the trunk fits snug into the corner of the floorpan. |
sixnotfour |
Mar 30 2008, 10:41 AM
914 Wizard Group: Members Posts: 10,433 Joined: 12-September 04 From: Life Elevated..planet UT. Member No.: 2,744 Region Association: Rocky Mountains |
Just like Andy, Factory installed
Attached image(s) |
J P Stein |
Mar 30 2008, 12:10 PM
Irrelevant old fart Group: Members Posts: 8,797 Joined: 30-December 02 From: Vancouver, WA Member No.: 45 Region Association: None |
I wouldn't use a rear sway bar unless you have an LSD......or even then, come to think of it. (IMG:style_emoticons/default/biggrin.gif)
Racer |
Apr 15 2008, 04:56 PM
Senior Member Group: Members Posts: 787 Joined: 25-August 03 From: Northern Virginia Member No.: 1,073 Region Association: MidAtlantic Region |
I wouldn't use a rear sway bar unless you have an LSD......or even then, come to think of it. (IMG:style_emoticons/default/biggrin.gif) Why is that? Others have mentioned this too. I've always had a rear sway bar in my 914s and thought they were fine. |
SirAndy |
Apr 15 2008, 05:42 PM
Why is that? Others have mentioned this too. I've always had a rear sway bar in my 914s and thought they were fine. wheel lift ... on a car *without* substantial stiffening like full rollcage tied into the shock towers etc. you'll twist the tub when cornering hard. the rear swaybar will lift the unloaded tire up in the air and instead of going forward, all the uhmmmpf goes into spinning the unloaded tire ... (IMG:style_emoticons/default/bye1.gif) Andy |
J P Stein |
Apr 15 2008, 07:07 PM
"Funny" things happen to 914s as you add increased grip.
Finding the good set up to optimize each new set of stickier tires as one progresses thru the stages to.... wherever, is a challenge. Here's a couple pics separated by 4 years. In the green car pic, notice the curved black line following the car around. In the yellow car pic, notice the weight transfer to the outside rear tire. Same car, different set up, but a similar situation.....accelerating (or trying to) around a corner. No rear sway bar. Attached image(s) |
craig downs |
Apr 24 2008, 07:33 PM
Senior Member Group: Members Posts: 768 Joined: 25-November 05 From: mira loma ca. Member No.: 5,189 Region Association: Southern California |
So with no rear bar do you dial in the rear suspension with the spring rate
J P Stein |
Apr 24 2008, 08:47 PM
So with no rear bar do you dial in the rear suspension with the spring rate That is the method I use. The green car pic is with (IIRC) 250 lb springs. I went to 300s and that cured it....then backed down to 275s and it was still OK......21mm T bars up front. There needs to be balance F to R to get the front bar in an optimal range of adjustment for your preferred over or understeer. Half way hard is gud. I assume there are other ways to get there, but you NEVER want to lift that inside rear. I now run a torque biasing LSD. They won't work if the inside tire is off the ground. A clutch type will but they will give you a push (understeer) at AX. |
craig downs |
Apr 24 2008, 11:12 PM
Interesting
Thanks J P |
Lo-Fi Version | Time is now: 2nd June 2024 - 03:20 AM |
