Side decal application tips?, From those who have done it |
914zim |
Jan 16 2004, 10:34 AM
Still pretty clueless... Group: Members Posts: 221 Joined: 29-July 03 From: New Berlin, WI Member No.: 962 |
Dudes:
I got the side decals from the guy on ebay that sells them. I was going to try and put them on tonight, so I wanted to see if anyone had done this already and might have a few tips for me. Thanks! Andy... |
boxstr |
Jan 16 2004, 11:08 AM
MEMBER:PACIFIC NORTHWEST REGION Group: Members Posts: 7,522 Joined: 25-December 02 From: OREGON Member No.: 12 Region Association: Pacific Northwest |
I f I were putting one on a car I would put it on the lower rocker panels, that way if you selll the car the new owner if they want to remove them won't have to try and scrap it from the body of the car.
CCLINSIDEDECALVILLE |
VegasRacer |
Jan 16 2004, 01:21 PM
ELVIRA Group: Benefactors Posts: 8,518 Joined: 27-March 03 From: Between Scylla and Charybdis Member No.: 481 Region Association: None |
Get a spray bottle. Fill it with water. Add a few drops of liquid soap. When you peel off the back of the decal, spray it and get it dripping wet. Then you can put the decal on the car and slide it around to get the exact placement you want. Use a squeegee to drain the water and remove air bubbles. Press hard but don't stretch the decal. When it dries it will be perfectly flat.
914werke |
Jan 16 2004, 01:56 PM
"I got blisters on me fingers" Group: Members Posts: 10,104 Joined: 22-March 03 From: USofA Member No.: 453 Region Association: Pacific Northwest |
Rockers ! Im sorry Craig but that would be FUGLY (IMG:style_emoticons/default/blink.gif)
914zim |
Jan 16 2004, 05:24 PM
Alright, thanks fellas!
Now I'm wondering if I can get the heater in the garage to bring the temp up to something reasonable! It's about 25 degrees here in WI! My hands are getting cold just thinking about it. Andy... |
Jeroen |
Jan 16 2004, 10:55 PM
914 Guru Group: Members Posts: 7,887 Joined: 24-December 02 From: The Netherlands Member No.: 3 Region Association: Europe |
Don't worry about removing them...
Hairdryer works magic. Heats up the glue and will peal off easily without paint damage cheers, Jeroen |
boxstr |
Jan 16 2004, 10:58 PM
My yellow car had a PORSCHE stripe down the side. Nothing would take the thing off without paint damage.
I have seen a black 914 with a silve PORSCHE stripe on the rocker panel. It did look good. CCLINNOSTRIPES |
Lo-Fi Version | Time is now: 29th May 2024 - 03:35 AM |
