Brake light blinking, new m/c install |
Thack |
Apr 16 2008, 03:45 PM
Member Group: Members Posts: 283 Joined: 1-June 05 From: Houston, Tx Member No.: 4,182 |
I read somewhere if your emergency brake light on the dash is blinking after a m/c install, you have to re-set the switch. How do I do this?
dr914@autoatlanta.com |
Apr 16 2008, 03:53 PM
914 Guru Group: Members Posts: 7,894 Joined: 3-January 07 From: atlanta georgia Member No.: 7,418 Region Association: None |
I read somewhere if your emergency brake light on the dash is blinking after a m/c install, you have to re-set the switch. How do I do this? on the single pole boot there is a small rubber booted reset switch next to the wire terminal. It is of course on the side of the cylinder up underneath the rack and pinion cover |
Thack |
Apr 16 2008, 04:43 PM
the reset switch is in the wiring to the pole or it's on the m/c?
Is this it? Attached image(s) |
blitZ |
Apr 16 2008, 05:01 PM
Beer please... Group: Members Posts: 2,223 Joined: 31-August 05 From: Lawrenceville, GA Member No.: 4,719 Region Association: South East States |
That's it.
zymurgist |
Apr 17 2008, 06:20 AM
"Ace" Mechanic Group: Members Posts: 7,411 Joined: 9-June 05 From: Hagerstown, MD Member No.: 4,238 Region Association: None |
Doesn't it also blink if there is an open circuit on the switch that is operated by the hand brake lever?
Spoke |
Apr 17 2008, 07:33 AM
Jerry Group: Members Posts: 6,991 Joined: 29-October 04 From: Allentown, PA Member No.: 3,031 Region Association: None |
Doesn't it also blink if there is an open circuit on the switch that is operated by the hand brake lever? Normal operation of MC switch and E-brake switch are open circuits. These 2 guys are wired in parallel from ground to the indicator circuit such that closing either one of the switches causes the dash indicator to light. |
zymurgist |
Apr 17 2008, 12:08 PM
Hmmm. Here's what happened with Babydoll. I was able to get the blinking to stop, when I adjusted the switch exactly right on the parking brake lever. (It rarely does line up right, but in this case I was able to get it to work.) Later, I had to pull the driver's seat to fix the seat mechanism, and in the process I broke off the connector that goes to the switch. So it's definitely an open circuit now, but the light keeps a-blinking.
This would bother me more if I actually drove the car, but it and its owner are 80 miles away. (IMG:style_emoticons/default/wink.gif) |
Lo-Fi Version | Time is now: 7th June 2024 - 11:59 AM |
