PeeGreen 914 |
Just when you think you're done...wait, there is more..lol ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 10,219 Joined: 21-September 06 From: Seattle, WA... actually Everett Member No.: 6,884 Region Association: Pacific Northwest ![]() ![]() |
For those of you that know this sort of thing.... I put the coil off my 2.0l 6 onto the 2.4l. I would think they are the same, but I am just checking with the pros as to if that could be causing my problems.
Root_Werks |
Village Idiot ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 8,739 Joined: 25-May 04 From: About 5NM from Canada Member No.: 2,105 Region Association: Pacific Northwest ![]() ![]() |
Shouldn't, you should have been using the 3 pin CD box correct? If so, that should be fine. I have an extra coil and 3 pin box I'll bring with me tomorrow just in case. (IMG:style_emoticons/default/wink.gif)
Mark Henry |
that's what I do! ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 20,065 Joined: 27-December 02 From: Port Hope, Ontario Member No.: 26 Region Association: Canada ![]() |
If it's a blue coil it's the same...I've seen them on 12cyls.
Now if it's a high volt aftermarket coil it can melt points. Dan says CD box, I don't use them, but as long as it's rated for the coil no problem. |
Root_Werks |
Well, I say CD box only becuase it is what probably was on his 914 to begin with. That said the system should still be the same and work fine. If it has an MSD box or if his 2.0 had point/condensor without a CD box, then things change. Either way, I'll bring over some parts and we'll get something together.
SLITS |
"This Utah shit is HARSH!" ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Benefactors Posts: 13,602 Joined: 22-February 04 From: SoCal Mountains ... Member No.: 1,696 Region Association: None ![]() ![]() |
Hey John, as I understand the systems they used (and we are talking /6 systems), the early cars '65 - '67? used a conventional point / coil system. The coil is fed 12 VDC with an internal resistor (Bosch Blue) or other cars an external resistor which drops the 12 VDC to about 9 VDC feeding the coil.
If you feed the conventional system 12 VDC it will burn the points, possibly the center electode of the cap, etc. And yes I did it many years ago and found this out. The CDI system uses a transformer (not called a coil in the books). It is fed 300 - 400 VDC by the CDI box. Using a "Coil" from an earlier car with a CDI could feasibly overheat it and short the windings (pure speculation on my part). Take this information for what you want .... |
Root_Werks |
If I remember what Jon told me, his engine will not rev above 4k rpms. That would maybe be a points ignition mixed with a CD system. Or fried point (or weak points) or if it's set up right as a 3 pin CD system, still bad points, bad CD box or bad coil.
I didn't ask him if he simply took his ign system off his 2.0 as a whole and just swapped it over to the 2.4. If his 2.0 was early enough and parts have been mixed, say he is running pre 68' coil but doesn't have a condensor on his 2.4 dizzy, then that will explain a lot. If we get stuff figured out tomorrow, we'll post the results here. |
SLITS |
In addition to what you said Dan ...
1.) Dizzy advance not working / dwell way off 2.) 2.4L would have most likely had a RPM limiting rotor ... they have been known to give up. The sound the engine makes when it shorts to ground is very discernable. Good luck ... have fun ... and remember that the Doctor is always available ... 24 hours a day. |
Root_Werks |
Well oh slity one, while we were discussing timming and ign issues, Jeff (Sixnotfour) swung by and helped them figure it out. I talked to Jon and it sounds like it was just carb adjustments. Cool! Jon, you gotta put some miles on that engine now.
(IMG:style_emoticons/default/driving.gif) |
messix |
AKA "CLUTCH KILLER"! ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 6,995 Joined: 14-April 05 From: between shit kickers and pinky lifters/ puget sound wa.north of Seattle south of Canada Member No.: 3,931 Region Association: Pacific Northwest ![]() |
Jeff to the rescue!!!!!!!!!!!!! (IMG:style_emoticons/default/smilie_pokal.gif) (IMG:style_emoticons/default/pray.gif)
SLITS |
Carbs .... what the hell are they?
Nice work Jeff. |
PeeGreen 914 |
They were jetted too small. Weird as it was working on the car it came out of, but oh well. We will put the new jets in tomorrow once we get them from Jeff. He really IS the man.
championgt1 |
Don't embarrass me Filmore! ![]() ![]() ![]() ![]() Group: Members Posts: 2,681 Joined: 3-January 07 From: Tacoma, Washington Member No.: 7,420 Region Association: Pacific Northwest ![]() |
Jon,
Glad to hear you got it figured out. Looks very nice. |
PeeGreen 914 |
Thanks Jack. I too am glad we solved it and it was simple rather than needing to pull the engine again. (IMG:style_emoticons/default/piratenanner.gif) I do all the grunt work and the pros come do the fine tuning... I don't know what I'm doing when it comes to that stuff.
championgt1 |
Cool.
I helped rhodyguy drop his motor today. It was my first experience at a motor drop, and was a great learning experience. Not to bad actually, but it is nice to hear you don't have to drop yours again. |
PeeGreen 914 |
Yeah... It's really not very hard...especially when you're using a lift (IMG:style_emoticons/default/smile.gif) I did mine by myself. I really did most of the grunt work myself. It wasn't until I went to have the motor mount welded in that I needed help... Then came the stuff I don't know how to do... and Tim has helped a ton in that area and Jeff bailed us both out. Those two together have more experience than I believe I ever will in two lifetimes.
Lo-Fi Version | Time is now: 12th July 2025 - 10:52 AM |
