I was saving money for a front sway bar, to find out I already have one |
jsayre914 |
May 8 2008, 11:07 AM
Speed Up !!! Group: Members Posts: 3,188 Joined: 10-February 08 From: Timonium MD 21093 Member No.: 8,696 Region Association: MidAtlantic Region |
(IMG:style_emoticons/default/piratenanner.gif) I pulled the wheels off my 914 that I bought in November. It has been on jack stands since I bought it. I have spent so much time in the engine bay and interior of the car I never got around to pulling the wheels. So I found a factory sway bar in the front this morning (IMG:style_emoticons/default/biggrin.gif) how cool is that. I just saved myself time and money (IMG:style_emoticons/default/beerchug.gif)
Attached image(s) |
rhodyguy |
May 8 2008, 11:10 AM
Chimp Sanctuary NW. Check it out. Group: Members Posts: 22,093 Joined: 2-March 03 From: Orion's Bell. The BELL! Member No.: 378 Region Association: Galt's Gulch |
that saved some dough. rebush the drop links. cheap and easy. does your car have one on the rear too? same applies.
k |
purple |
May 8 2008, 11:14 AM
Pigeon feeders attract me Group: Members Posts: 938 Joined: 24-July 07 From: Houston, TX Member No.: 7,942 Region Association: None |
How would you re-bush the rear drop links?
rhodyguy |
May 8 2008, 11:20 AM
press new bushings in the drop links? the top ones that secure the bar to the car are easy.
purple |
May 8 2008, 11:24 AM
I must be a puss like my avatar, because getting those bushings in the drop links is NOT HAPPENIN!
rhodyguy |
May 8 2008, 11:32 AM
heat them up, a little grease on the link and the bushings. edevour to persevere. not that big of a deal to put them in. just make sure you don't put them in with the hole facing the same direction on the droplink.
k |
jsayre914 |
May 8 2008, 11:38 AM
that saved some dough. rebush the drop links. cheap and easy. does your car have one on the rear too? same applies. k Nothing on the rear. You cant win em all. dont most prefer front only anyway?? (IMG:style_emoticons/default/dry.gif) |
purple |
May 8 2008, 11:45 AM
having just the front on mine makes it much more controllable should I get sideways. The rear one makes the ass swap around a little fast. Although my car is far from well set up....
So.Cal.914 |
May 8 2008, 12:10 PM
"...And it has a front trunk too." Group: Members Posts: 6,588 Joined: 15-February 04 From: Low Desert, CA./ Hills of N.J. Member No.: 1,658 Region Association: None |
I agree, the ass end does come around quicker, when it lets go. But it sure stays
flat and true until then. (IMG:style_emoticons/default/smile.gif) |
shelby/914 |
May 8 2008, 12:58 PM
Senior Member Group: Members Posts: 804 Joined: 24-August 05 From: Foxfield, Co Member No.: 4,655 Region Association: Rocky Mountains |
I've got both front and rear swaybars and I never notice the rear coming around. Of course it's either on jack stands or in the body shop so it generally doesn't move at all.
purple |
May 8 2008, 02:14 PM
I've got both front and rear swaybars and I never notice the rear coming around. Of course it's either on jack stands or in the body shop so it generally doesn't move at all. I heard that! I have had mine off stands for over two months now! Sadly, it's going back on this weekend. Putting a whole new brake system on there. all 4 wheels off the ground, never done that before... |
914Sixer |
May 8 2008, 04:22 PM
914 Guru Group: Members Posts: 8,906 Joined: 17-January 05 From: San Angelo Texas Member No.: 3,457 Region Association: Southwest Region |
What year is the car? Strange that you would have a factory setup in the front and not one in the rear. Check to see if your lower bolts on the shocks have balls on the end. Also look up and see if the mounting backets are there. Somebody may have removed it at some point.
jsayre914 |
May 8 2008, 04:45 PM
What year is the car? Strange that you would have a factory setup in the front and not one in the rear. Check to see if your lower bolts on the shocks have balls on the end. Also look up and see if the mounting backets are there. Somebody may have removed it at some point. From what iv read in my last search, Im not sure if it is put from factory or previous owner. I guess there is no real way to tell (IMG:style_emoticons/default/huh.gif) It looks factory to me. My car is a 73 2.0 |
Lo-Fi Version | Time is now: 9th June 2024 - 08:54 PM |
