> Question about Master Cylinder
WizPorsche914
post May 15 2008, 08:52 PM
I have a question. Im going to replace my Master Cylinder soon. What tools will I need to do the job and is it easy.
Joe Bob
post May 15 2008, 08:56 PM
First you buy one of the Clymer or Haynes books. Read it.....you'll need clean fluid, 13,12,11,10mm wrenches at least....then the bleeder screw wrenches which are 8mm in most cases and sometimes smaller.
If you don't have a complete set of metirc wrenches you should be heasding to Sears....
it's about a seven on the 1-10 scale. A lot of people suggest bench bleeding the cylinder before installation. Unless you have help you'll need a pressure bleeder to do the calipers...
TravisNeff
post May 15 2008, 08:58 PM
13mm wrench: for the MC to the body of the car
needle nose pliers, to pull the electrical connector(s) and pull/install the feed tubes
It's a fairly straightforward job, but it is a real bitch to get the feed lines seated into the new MC.
Joe Bob
post May 15 2008, 08:59 PM
Oh yeah, don't forget the reset button on the side....
So.Cal.914
post May 15 2008, 09:06 PM
"...And it has a front trunk too."
!Wet Spot! May 15 2008, 07:59 PM Post #4
Stoopid people piss me off.....
Wetspot? (IMG:style_emoticons/default/av-943.gif) (IMG:style_emoticons/default/av-943.gif) (IMG:style_emoticons/default/av-943.gif)
Joe Bob
post May 15 2008, 09:09 PM
It's what my Dad used to call me when he was pissed at me.....
ejm
post May 15 2008, 09:24 PM
I can see the light at the end of the tunnel
QUOTE(Travis Neff @ May 15 2008, 10:58 PM) *
Loosen the reservoir retaining strap and you can slide the feed lines down a couple of inches. Also keep track of which line went where, if you reverse them they don't fit right.
IronHillRestorations
post May 16 2008, 11:56 AM
I. I. R. C.
Sometimes a flare wrench works much better than an open end on the brake line fittings.
ericread
post May 16 2008, 01:38 PM
The Viper Blue 914
QUOTE(So.Cal.914 @ May 15 2008, 08:06 PM) *
It's where you sleep when you're in "Love"..
Cap'n Krusty
post May 16 2008, 02:30 PM
Cap'n Krusty
QUOTE(9146986 @ May 16 2008, 10:56 AM) *
And a 7mm wrench is a better fit than an 8mm wrench on the 7mm bleeders. The Cap'n
trapper
post May 18 2008, 07:01 PM
I just put a 23mm M/C on my 914-6 this past Saturday and am having problems seating the feed lines. Now I'm wondering if I screwed up and crossed the lines. Does anybody have a picture or know which line goes where. There is a left and right coming through the body under the gas tank. Does the left line (outer) go to the front or rear of the M/C? Also, is it easier to put the black rubber grommets on the lines and them insert into the M/C or try to put the lines into the grommets in the M/C? Any special tools you have used for this? Thanks.[i]java script:emoticon(':(', 'smid_2')
(IMG:style_emoticons/default/sad.gif)
trapper
post May 19 2008, 06:59 PM
It's done, now I remember why I didn't want to change one of those again!
(IMG:style_emoticons/default/headbang.gif) Now for a (IMG:style_emoticons/default/beer3.gif)
rfuerst911sc
post May 19 2008, 07:10 PM
QUOTE(trapper @ May 19 2008, 04:59 PM) *
Any tips or tricks to share? Did you end up pushing the lines in the grommets or putting the grommets on the lines and then inserting?
- Lo-Fi Version Time is now: 1st July 2025 - 07:17 AM
