bbrown |
Member ![]() ![]() Group: Members Posts: 92 Joined: 23-December 04 From: ohio Member No.: 3,330 ![]() |
Which model # do I need so that the post are on the correct side. Thanks
dr914@autoatlanta.com |
914 Guru ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 7,900 Joined: 3-January 07 From: atlanta georgia Member No.: 7,418 Region Association: None ![]() |
a 42
ericread |
The Viper Blue 914 ![]() ![]() ![]() ![]() Group: Members Posts: 2,177 Joined: 7-December 07 From: Irvine, CA (The OC) Member No.: 8,432 Region Association: Southern California ![]() |
a 42 ?? Is this a specific body number or are we playing bingo? Oops - I thought I was in a different forum subject. A42 is the battery. My bad... (IMG:style_emoticons/default/confused24.gif) |
jetboy |
914 Uber Noob ![]() ![]() Group: Members Posts: 205 Joined: 16-September 05 From: Riverside, CA Member No.: 4,810 Region Association: Southern California ![]() |
Is there a link to that model? I cant seem to find it on a lot of retail websites. I see 25, 34, 34R, 35, and 75 mostly for red tops. I must be a battery noob.
orthobiz |
Senior Member ![]() ![]() ![]() Group: Members Posts: 1,754 Joined: 8-January 07 From: Cadillac, Michigan Member No.: 7,438 Region Association: Upper MidWest ![]() ![]() |
Straight from Steve Gaglione,
"I though this was pretty well known on this site but I'll repeat....... if you decide on the Red top, order the 34R. The 34R has the terminals in the correct position for the 914. NSN: 6140 01 475 9357 I'm also told that a lot of people use the group 78 adapter to secure the battery to the tray. By the way I've always used a regular battery in all my 914's except my race cars but I will probably go with the red top for the M471 car." The original link... The adapter is cool... Paul |
Root_Werks |
Village Idiot ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 8,338 Joined: 25-May 04 From: About 5NM from Canada Member No.: 2,105 Region Association: Pacific Northwest ![]() ![]() |
Dudes, don't those things wiegh a ton? Why not get a dry cell? I've been running one in my 914 for almost 2 years. Works great and I can pick it up with one hand (no handle). It weighs I think 20lbs? Super small and like any dry cell, can be mounted anywhere.
Attached image(s) ![]() |
Root_Werks |
Part number for the one I have is PC925LMJ
Rusty |
Wanted: Engine case GA003709 ![]() ![]() ![]() ![]() ![]() Group: Admin Posts: 7,942 Joined: 24-December 02 From: North Alabama Member No.: 6 Region Association: Galt's Gulch ![]() ![]() ![]() |
Steve's words are wisdom, but I doubt the NSN is going to help anyone very much... it's the number the government uses to purchase the item through their supply system.
In the referenced thread, there is debate about a "short life" of an Optima. As the owner of several - if you leave the Optima connected to a car all winter, it's going to be as dead as disco, come spring-time. The Bumblebee has a clock which is a constant battery drain and doesn't get driven in the winter. It's on the third Optima... because I didn't realize that I was the dumbass that just didn't disconnect the battery cables before winter storage. Once I figured that out - no more battery failures. My Wrangler has an Optima. After 12 months of storage while I was overseas, it started right up after reconnecting the cables. They hold a strong charge over time. No acid venting or dripping. You can't go wrong. (IMG:style_emoticons/default/smile.gif) |
orthobiz |
orthobiz |
PeeGreen 914 |
Just when you think you're done...wait, there is more..lol ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 10,219 Joined: 21-September 06 From: Seattle, WA... actually Everett Member No.: 6,884 Region Association: Pacific Northwest ![]() ![]() |
Dudes, don't those things wiegh a ton? Why not get a dry cell? I've been running one in my 914 for almost 2 years. Works great and I can pick it up with one hand (no handle). It weighs I think 20lbs? Super small and like any dry cell, can be mounted anywhere. This is the battery to get. I have one on order and hope to get it soon. The read tops are about 50 some odd pounds and these are less than 25. They even crank harder as well. |
Root_Werks |
Dudes, don't those things wiegh a ton? Why not get a dry cell? I've been running one in my 914 for almost 2 years. Works great and I can pick it up with one hand (no handle). It weighs I think 20lbs? Super small and like any dry cell, can be mounted anywhere. This is the battery to get. I have one on order and hope to get it soon. The read tops are about 50 some odd pounds and these are less than 25. They even crank harder as well. 925CCA for the first 5 seconds. 5 seconds is a loooooong time to crank on a car. 20 months and mine still works like it was new. Its life is something like 7 years as well. (IMG:style_emoticons/default/wink.gif) |
Lo-Fi Version | Time is now: 17th June 2024 - 07:41 AM |
