where to get ebrake cable extensions? |
rfuerst911sc |
Jun 1 2008, 02:16 PM
Advanced Member Group: Members Posts: 2,158 Joined: 4-May 06 From: Dahlonega , Georgia Member No.: 5,980 Region Association: South East States |
I have converted my 914 to 5 lug and 911 ebrake. I cutoff the OEM ebrake mounting tabs on the swing arm and welded them back on but straight back. Now that that is done I need cable extensions aprox. 6-7 inches long. Ideally these extensions would have eyelets on both ends. Where do you go to have something like this made? This is just a cable with no sheathing, I welded a bolt onto the bottom of each swing arm and mounted a bearing wheel. I'm expecting the cable extension to ride in this wheel. Any ideas?
dr914@autoatlanta.com |
Jun 1 2008, 08:36 PM
914 Guru Group: Members Posts: 7,898 Joined: 3-January 07 From: atlanta georgia Member No.: 7,418 Region Association: None |
I have converted my 914 to 5 lug and 911 ebrake. I cutoff the OEM ebrake mounting tabs on the swing arm and welded them back on but straight back. Now that that is done I need cable extensions aprox. 6-7 inches long. Ideally these extensions would have eyelets on both ends. Where do you go to have something like this made? This is just a cable with no sheathing, I welded a bolt onto the bottom of each swing arm and mounted a bearing wheel. I'm expecting the cable extension to ride in this wheel. Any ideas? Don't do it !!!!!! It makes the control arms way too heavy and strains the frame. |
John |
Jun 2 2008, 01:03 AM
member? what's a member? Group: Members Posts: 3,393 Joined: 30-January 04 From: Evansville, IN (SIRPCA) Member No.: 1,615 Region Association: None |
Don't do it !!!!!! It makes the control arms way too heavy and strains the frame. What are you smokin' George? Please post a picture. Many have successfully invented a belcrank arrangement for this. Total weight addition less than a pound...... Attached image(s) |
rfuerst911sc |
Jun 2 2008, 05:47 PM
My setup is different from others as I didn't plan on useing a bellcrank to activate the 911 ebrake. My plan was/is to extend the OEM 914 cables with aircraft cable with no sheathing to wrap around the roller bearing pulleys in the pic. Any suggestions are appreciated. (IMG:style_emoticons/default/beerchug.gif)
Attached image(s) |
RON S. |
Jun 5 2008, 02:06 PM
9140430841, FINALLY RUNNING Group: Members Posts: 1,212 Joined: 22-May 03 From: WALTERBORO,S.C. Member No.: 724 Region Association: South East States |
here is an old pic of my setup.
it works just fine, and i haven't had any problems. Ron Attached image(s) |
Lo-Fi Version | Time is now: 11th June 2024 - 12:47 PM |
