check my wishlist, anything missing? |
stateofidleness |
Jun 6 2008, 11:55 PM
Senior Member Group: Members Posts: 810 Joined: 1-September 07 From: Canyon Lake, Texas! Member No.: 8,065 Region Association: None |
This is my wishlist from AutoAtlanta.com.
(some of the items have the wrong qty listed, i guess it defaults to 1 when it emails) Questions: I had one exhaust stud come out when i took the heat exchangers off, so is that the right stud i will need to replace the old one with? for the air injection tubes, i would like to be able to plug the actual hole in the head as opposed to leaving the tubes (looks kinda funny...)... do they make a plug "bolt" or is my only option the 4 "caps"? anything i should add? not purchase from AA, maybe somewhere cheaper? let me know.. may be a huge chunk of change if i go with all AA |
rhodyguy |
Jun 6 2008, 11:59 PM
Chimp Sanctuary NW. Check it out. Group: Members Posts: 22,089 Joined: 2-March 03 From: Orion's Bell. The BELL! Member No.: 378 Region Association: Galt's Gulch |
what does a $71.50 upper fuel line kit consist of? fuel line cut to length? new shouldered clamps? seventy one fifity. oh, + shipping and handling? you need to check the size of the pulled stud if you haven't done so.
stateofidleness |
Jun 7 2008, 12:05 AM
what should i check on it? i kind of feared i would run into the "pulled stud" problem because i dont know how to repair it... do i need to measure the length, diameter or what?
yea, I believe it is just fuel line precut for the engine compartment section http://www.autoatlanta.net/record_detail.l...467&-Search thoughts? |
type47 |
Jun 7 2008, 09:25 AM
Viermeister Group: Members Posts: 4,254 Joined: 7-August 03 From: Vienna, VA Member No.: 994 Region Association: MidAtlantic Region |
$71 buys alot of fuel line at the local FLAPS and alot of razor blades to cut at the local ACE hardware. buy some backup/extra step studs instead.
rhodyguy |
Jun 7 2008, 09:37 AM
you need to be sure that a step up stud has not been previously installed.
Lo-Fi Version | Time is now: 4th June 2024 - 02:22 PM |
