Headlight Switch - How to remove? |
Eddie914 |
Jan 24 2004, 10:36 AM
Unregistered |
My '71 914 1.7/2.7 has no working instrument lighting. I'm guessing the dimmer rheostat is shot.
I can't get my hand behind the dash to pull out the switch. What is the best way to get the switch out? - Pull the instrument panel? - Remove the fuse panel? - Remove the complete dash? - Dynamite? Thanks |
Dave_Darling |
Jan 24 2004, 12:22 PM
I believe that I've gotten room to do that by removing the fuse panel. Two screws hold it up; you can let it dangle by the wires as long as you don't have any loose wires around there. A smart person would disconnect the battery first. (I'm not smart...)
Unscrewing what the manual calls the "escutcheon" (and I call a round flat nut) can be a bit tough. I can usually get it started by using a small screwdriver in one of the slots that extend out from the center hole, then use my fingers to push in on and turn the nut after it is started. You have to unscrew the knob first, of course. --DD |
smrz914 |
Jan 24 2004, 06:40 PM
Soon to be brightening the life of the person behind you. Group: Members Posts: 456 Joined: 21-April 03 From: Pleasant Hill, CA or Chico, CA Member No.: 596 |
I've taken off the knee pad to get more room as well.
Lo-Fi Version | Time is now: 8th June 2024 - 09:22 AM |
