| ruddyboys |
Jun 30 2008, 09:42 AM
Hummel eigentümer ![]() ![]() ![]() Group: Members Posts: 595 Joined: 3-March 04 From: Monroe, NY Member No.: 1,749 Region Association: North East States |
My TV has only 1 set of RCA inputs, the problem I have a DVD and Wii that need to go into it. I was hoping to find an adapter that would let me take the DVD's RCA plugs and plug it into the coax input of my cable box.
| r_towle |
Jun 30 2008, 09:43 AM
Custom Member ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 24,705 Joined: 9-January 03 From: Taxachusetts Member No.: 124 Region Association: North East States
best buy, circuit city etc all have them.
Rich |
| ericread |
Jun 30 2008, 10:22 AM
The Viper Blue 914 ![]() ![]() ![]() ![]() Group: Members Posts: 2,177 Joined: 7-December 07 From: Irvine, CA (The OC) Member No.: 8,432 Region Association: Southern California |
best buy, circuit city etc all have them. Rich (IMG:style_emoticons/default/agree.gif) Just make sure you buy a box with decent isolation between the inputs. Crossover will cause your picture to look fuzzy. Eric |
| Demick |
Jun 30 2008, 01:19 PM
Ernie made me do it! ![]() ![]() ![]() ![]() Group: Benefactors Posts: 2,312 Joined: 6-February 03 From: Pleasanton, CA Member No.: 257 |
Huh? Coax is an RF connector. Can't just pipe in video from RCA connectors. Would need a RF modulator to do that.
Better way is to get a switcher box. Plug lots of RCA or S-video and audio connections into it, and it outputs to a single set of A/V connectors. I've used this one in the past, and it worked excellent: Radio Shack A/V switch box |
| ericread |
Jun 30 2008, 01:22 PM
Huh? Coax is an RF connector. Can't just pipe in video from RCA connectors. Would need a RF modulator to do that. Better way is to get a switcher box. Plug lots of RCA or S-video and audio connections into it, and it outputs to a single set of A/V connectors. I've used this one in the past, and it worked excellent: Radio Shack A/V switch box I also (IMG:style_emoticons/default/agree.gif) If you have video inputs to the TV, it would be best to keep the signal in that format. If not, time to modulate and send out via coax (FR modulated signal). Again, make sure it modulates on a channel that is not being broadcast locally to avoid interference. Eric |
Lo-Fi Version | Time is now: 27th July 2026 - 10:11 PM |
