Turn signal indicator wiring help, '74 turn signal indicator wiring |
jt914-6 |
Jul 14 2008, 07:52 PM
Driving & working on teeners 41 years Group: Members Posts: 1,786 Joined: 3-May 08 From: Bryant, Arkansas Member No.: 9,003 Region Association: South East States |
I've got a '74 (made 10/73) 914 and I need someone to tell me what wires/colors go to the turn signal indicator lights in the tach. I'm using a six cyl. tach, and I have two type of indicator light sockets to use. I've looked at a '73 & '75's wiring and neither one seems to be like my '74. Does anyone know the correct colored wires to us on a '74? Thanks in advance.............JT
jt914-6 |
Jul 21 2008, 08:18 PM
Come on 914 owners, there must be plenty of '74 owners with a digital camera or someone who can pull out their tach enough to check the color and number or wires on the turn signal indicators................Waiting for some help teeners............
lotus_65 |
Jul 21 2008, 08:36 PM
Senior Member Group: Members Posts: 1,608 Joined: 21-March 05 From: minneapolis, mn Member No.: 3,795 Region Association: Northstar Region |
this is all i gots
computers4kids |
Jul 21 2008, 09:33 PM
Love these little cars! Group: Members Posts: 2,443 Joined: 11-June 05 From: Port Townsend, WA Member No.: 4,253 Region Association: None |
My 75 turn indicators wire is white with a blue stripe...only one wire. The 74's have two for two indicators. This link may help you.
lotus_65 |
Jul 21 2008, 09:47 PM
it looks like mine is blue, with a white stripe, but that wouldn't be consistant with Mark.
i can't look into it just now though... |
jt914-6 |
Jul 21 2008, 10:35 PM
My 75 turn indicators wire is white with a blue stripe...only one wire. The 74's have two for two indicators. This link may help you. Thanks, I have seen that link, but haven't had time to research it. My car has a blue W/white stripe for one of the indicators, but what wire goes to the other indicator? |
Dave_Darling |
Jul 21 2008, 11:05 PM
The 74 only had one turn signal indicator in the tach, just like the 75s and 76es. A few of the early-early 74 had 73 tachs, with two indicator lights in the tach. But they were wired up to the single existing signal wire, so both would flash at the same time.
--DD |
jt914-6 |
Jul 21 2008, 11:19 PM
The 74 only had one turn signal indicator in the tach, just like the 75s and 76es. A few of the early-early 74 had 73 tachs, with two indicator lights in the tach. But they were wired up to the single existing signal wire, so both would flash at the same time. --DD The wire I guess is the Blue/white stripe for the single indicator then. The four way lights & flasher work, but the turn signal switch doesn't make the front & rear lights work nor does the light in the tach. Any idea what that problem is? |
computers4kids |
Jul 21 2008, 11:35 PM
The 74 only had one turn signal indicator in the tach, just like the 75s and 76es. A few of the early-early 74 had 73 tachs, with two indicator lights in the tach. But they were wired up to the single existing signal wire, so both would flash at the same time. --DD (IMG:style_emoticons/default/agree.gif) Perhaps your relay is defective (square one in fuse panel)? Are the correct bulbs in the turn signals...I've seen people accidentaly mix up the single pole and double pole bulbs with bizzare results. |
jt914-6 |
Jul 21 2008, 11:47 PM
I thought that the flasher relay worked the emergency lights and the turn signal lights. My emergency four way lights work and the relay clicks. The left and right front and rear lights come and stay on with key off when the turn signal lever is in the left or right position. I know that they are supposed to do this. My problem is that the turn signal lights front and rear do not work when the key is on and the lever is in the left or right postion.
Lo-Fi Version | Time is now: 6th June 2024 - 06:15 PM |
