Attention suspension experts!, left rear trailing arm noise |
Elliot Cannon |
Jul 19 2008, 05:42 PM
914 Guru Group: Retired Members Posts: 8,487 Joined: 29-December 06 From: Paso Robles Ca. (Central coast) Member No.: 7,407 Region Association: None |
During my trip to the WCR I had a VERY loud squeek from the left rear suspension. After removing the shock, break and rear sway bar I can lift the trailing arm up with NO resistance and NO noise. Is it possible that it could be noisy only with the weight of the car on it? I bought some polygraphite bushings for it. Should I use them or opt for the more expensive roller bearing bushing, or poly bronze etc.? Are the rear roller bearing bushings even available any more?
Cheers, Elliot Attached thumbnail(s) |
Joe Bob |
Jul 19 2008, 06:31 PM
Retired admin, banned a few times Group: Members Posts: 17,427 Joined: 24-December 02 From: Boulder CO Member No.: 5 Region Association: None |
Does it wobble side to side? You need to disconnect the CV to find out....the bushing could be toast....I know the one on my recent blue car was....heard the same noise.
BMXerror |
Jul 19 2008, 06:38 PM
Senior Member Group: Members Posts: 1,705 Joined: 8-April 06 From: Hesperia Ca Member No.: 5,842 |
Was is one very loud squeak, or was it a continuous thing? Did it do it randomly or was it when you loaded that side?
I, at this very moment, am actually dealing with a broken left rear trailing arm (and several other things now) . It showed up as a small click when I made hard right hand corners, but I could see it being a squeak or creek if it got bad enough. Mark D. |
r_towle |
Jul 19 2008, 06:52 PM
Custom Member Group: Members Posts: 24,591 Joined: 9-January 03 From: Taxachusetts Member No.: 124 Region Association: North East States |
If the squeak only occurs when the sway bar and shocks are hooked up your problem is probably in one of those units.
I would suspect the rear sway bar drop link. The rear bearings are available from Shine Racing (www.srsvw.com) Rich |
sww914 |
Jul 19 2008, 07:26 PM
Advanced Member Group: Members Posts: 2,439 Joined: 4-June 06 Member No.: 6,146 Region Association: None |
Polygraphite bushings are well known for squeeking. They probably need to be greased. Neuspeed (H20 VW nuts) recommends their own grease for their bushings, it's just silicone grease.
I can't see any zerk fittings in your photo. You can either disassemble the suspension and grease things or add zerks and put about 25 tubes of grease in there the first time to fill up all the space and then a few squeezes of grease here and there as it needs it. I like to groove the polygraphite bushings and drill them so that the grease will make it everywhere. There's no guarantee that the bushings are your problem but it seems likely to me. I've seen them not make any noise without the car's weight on the and then start squeeking again as soon as you put it on the ground. The Elephant Racing bronze bushings don't squeek and neither do the roller bearings, but they both cost some real money compared to the polygraphite. Personally I'd grease the existing bushings until I got sick of it and then I'd go spend some money. I have the plastic bushings. I figure that the $1000.00 spent on bushings won't make me faster around the track. $1000.00 spent on more track time will. |
Elliot Cannon |
Jul 20 2008, 03:05 AM
Does it wobble side to side? You need to disconnect the CV to find out....the bushing could be toast....I know the one on my recent blue car was....heard the same noise. I think you're right. Even with the CV hooked up, if I apply a side load to the brake rotor I can see a slight movement. I think the bushings went to heaven. |
PeeGreen 914 |
Jul 20 2008, 03:22 AM
Just when you think you're done...wait, there is more..lol Group: Members Posts: 10,219 Joined: 21-September 06 From: Seattle, WA... actually Everett Member No.: 6,884 Region Association: Pacific Northwest |
With everything you have into your car... and even though you are thinking of selling... I would put in the Elephant Racing poly bronze. Everyone I have talked to about using them say DO IT. They say it is great for a street or race car and adds so much to the suspension for feel. You car deserves it.
You should have just traded me (IMG:style_emoticons/default/biggrin.gif) |
Jeffs9146 |
Jul 20 2008, 12:07 PM
Ski Bum Group: Members Posts: 4,062 Joined: 10-January 03 From: Discovery Bay, Ca Member No.: 128 |
Check to see if your suspension ear is ovaled!!
Attached image(s) |
Jeffs9146 |
Jul 20 2008, 12:09 PM
Repair if nessary!
Attached image(s) |
Lo-Fi Version | Time is now: 10th June 2024 - 01:12 AM |
