Flasher Wiring, How do I add to the circuit ? |
jim_hoyland |
Aug 21 2008, 09:07 PM
Get that VIN ? Group: Members Posts: 9,319 Joined: 1-May 03 From: Sunset Beach, CA Member No.: 643 Region Association: Southern California |
Currently my seat belt warning light works as expected, it just doesn't flash when its on. It appears to have been rewired to just get it working.
I would like to know how to add it to the flasher circuit. |
Cap'n Krusty |
Aug 21 2008, 09:14 PM
It's not supposed to flash. The Cap'n
jim_hoyland |
Aug 21 2008, 09:21 PM
hockeymutt |
Aug 21 2008, 09:58 PM
Member Group: Members Posts: 84 Joined: 4-August 08 From: NJ Member No.: 9,388 Region Association: None |
relay....
you would have you would run the positive and ned wires to the relay and then run to new wires to the light bulb it shouldn't be that hard. but you could goto napa and pick up a flasher relay and solder all the wires to it. of course useing a multimeter to figure out which ones are power source(to control the relay) and then which one is activated once power is applied i cn draw it up for once i get more time. about to head out to the college to meet up with some new college girls..... |
jim_hoyland |
Aug 21 2008, 10:15 PM
relay.... you would have you would run the positive and ned wires to the relay and then run to new wires to the light bulb it shouldn't be that hard. but you could goto napa and pick up a flasher relay and solder all the wires to it. of course useing a multimeter to figure out which ones are power source(to control the relay) and then which one is activated once power is applied i cn draw it up for once i get more time. about to head out to the college to meet up with some new college girls..... Sketch will work for me. I want to use the existing flasher on the fuse panel if possible. Thanks |
ejm |
Aug 22 2008, 05:31 AM
I can see the light at the end of the tunnel Group: Members Posts: 2,694 Joined: 3-February 03 From: Massachusetts Member No.: 224 Region Association: None |
It may be easier to replace the bulb with a flashing LED.
jk76.914 |
Aug 22 2008, 09:32 AM
Senior Member Group: Members Posts: 809 Joined: 12-April 05 From: Massachusetts Member No.: 3,925 Region Association: North East States |
Bulb gets grounded through switches on seatbelt latches and butt-sensors in the seats.
Splice the other wire from the bulb into the white/green/black wire that goes from the flasher relay to the hand brake indicator in the dash. And you're done. Mine is wired this way. I think the flashing seatbelt light is a nice touch. |
jim_hoyland |
Aug 22 2008, 05:03 PM
Thanks for the wire diagram. I take it that white/green/black is always hot ?
jk76.914 |
Aug 22 2008, 05:12 PM
It's always hot until a load is passing through it, and then it flashes. I did a writeup a couple of years ago on how that flasher relay works. It's kind of interesting, I suppose. My writeup starts about 5 or 6 posts into the thread.
http://www.914world.com/bbs2/index.php?sho...c=47236&hl= |
jim_hoyland |
Aug 22 2008, 06:04 PM
It's always hot until a load is passing through it, and then it flashes. I did a writeup a couple of years ago on how that flasher relay works. It's kind of interesting, I suppose. My writeup starts about 5 or 6 posts into the thread. http://www.914world.com/bbs2/index.php?sho...c=47236&hl= That is a great write up. I had followed it to convert my turn signal indicators when you wrote the thread. |
jk76.914 |
Aug 22 2008, 06:34 PM
Oh thanks! The neat thing about it is when more than one thing flashes- directional, hazard, brake warning light, fasten seat belt light- they all flash in unison, and there's only one click.
Good luck, but this is an easy project! Jim |
jim_hoyland |
Aug 22 2008, 09:08 PM
Oh thanks! The neat thing about it is when more than one thing flashes- directional, hazard, brake warning light, fasten seat belt light- they all flash in unison, and there's only one click. Good luck, but this is an easy project! Jim Just completed the mod and it's still light out ! (IMG:style_emoticons/default/biggrin.gif) Very easy. |
Lo-Fi Version | Time is now: 9th June 2024 - 01:01 AM |
