low oil preasure |
low oil preasure |
honlude |
Sep 15 2008, 05:38 PM
Newbie Group: Members Posts: 23 Joined: 21-January 08 From: York Pa Member No.: 8,603 Region Association: MidAtlantic Region |
Hello , Quick question , I have a 75 1.8 , start and runs good , after i drive for a while , maybe 30 min the oil preasure light come on at idle , i have a small leak at the one push rod tube , i did replace the sender about a month ago figuring it maybe the problem , any help would be great , (im running 5/30 oil )
(IMG:http://i39.photobucket.com/albums/e188/honlude/1aporsche.jpg) |
carr914 |
Sep 15 2008, 05:42 PM
Racer from Birth Group: Members Posts: 119,001 Joined: 2-February 04 From: Tampa,FL Member No.: 1,623 Region Association: South East States |
r_towle |
Sep 15 2008, 05:43 PM
Custom Member Group: Members Posts: 24,588 Joined: 9-January 03 From: Taxachusetts Member No.: 124 Region Association: North East States |
run 20W50...
Rich |
TravisNeff |
Sep 15 2008, 06:52 PM
914 Guru Group: Members Posts: 5,082 Joined: 20-March 03 From: Mesa, AZ Member No.: 447 Region Association: Southwest Region |
I'm with Rich on this..
Cap'n Krusty |
Sep 15 2008, 07:10 PM
Yup. 20w50 unless you're where it freezes on a regular basis. 5w30 is waaaaaayyyy too thin. The Cap'n
sww914 |
Advanced Member Group: Members Posts: 2,439 Joined: 4-June 06 Member No.: 6,146 Region Association: None |
The oil's too thin. |
r_towle |
Sep 15 2008, 09:20 PM
SGB |
Sep 16 2008, 07:22 AM
just visiting Group: Members Posts: 4,086 Joined: 8-March 03 From: Huntsville, AL Member No.: 404 Region Association: South East States |
Also, I learned that the trip point is lower for the aftermarket VDO dual-pole oil pressure sender. Like 8 psi v. 5 psi for the stock one.
honlude |
Sep 16 2008, 09:19 AM
Thanks guys I'll try oil change first and see what happens , the sender is oem that I used
Joe Bob |
Sep 16 2008, 10:30 AM
Retired admin, banned a few times Group: Members Posts: 17,427 Joined: 24-December 02 From: Boulder CO Member No.: 5 Region Association: None |
"I" would run a straight weight oil. Also I would consider a heavy duty spring on the oil pressure relief valve....
Cap'n Krusty |
Sep 16 2008, 10:59 AM
Or you could just fix it right ....................
Good morning, Mike! The Cap'n |
Joe Bob |
Sep 16 2008, 11:01 AM
That involved a tear down and a rebuild.....at least on my Type I.
honlude |
Sep 16 2008, 12:37 PM
my plans are to tear motor out over winter and redo the entire thing but I'm just nickel and diming for the next month or so till then , I have a good lead on a 2.0 core and I am leaning on going that route if the guy comes thru
dbgriffith75 |
Sep 16 2008, 03:54 PM
TheGrif Group: Members Posts: 509 Joined: 25-July 07 From: Iowa, USA Member No.: 7,945 Region Association: Upper MidWest |
QUOTE my plans are to tear motor out over winter and redo the entire thing but I'm just nickel and diming for the next month or so till then , I have a good lead on a 2.0 core and I am leaning on going that route if the guy comes thru If your contact doesn't come thru for you let me know- i have a near complete 2.0 motor that I inherited when I bought my '75 that I've been saving for spare parts in case of emergency. I believe it's set up for D-Jet FI; tho from what I understand D-Jet can easily be converted to L-Jet if needed. But now that my other motor is rebuilt I don't have much use for it, so I'd probably send it to you for a good price. I should warn you, however, that it's not very pretty (previous owner had let it sit around for some years)... let me know if you're interested and I'll get you some pics. |
Lo-Fi Version | Time is now: 8th June 2024 - 10:04 AM |
