Throttle body leak |
415PB |
Feb 5 2004, 06:41 PM
Member Group: Benefactors Posts: 498 Joined: 7-August 03 From: So Cal Member No.: 996 |
Once the AAR kicks off after warm, the idle hunts from 1000 to 0 RPM. I changed the vacuum lines and it still hunts. So I tried the starting fluid trick and sprayed it at the base of the throttle body. The idle held right at 1000 rpm until the starting fluid dissipated and then it began to hunt again. I did this several times with the same results. Do you think Threebond 1104 can be used and work at the base of the throttle body? I ordered the gasket several months ago, but it has been on back order or is not available (cant remember which).
Thanks for the help. |
SirAndy |
Feb 5 2004, 06:43 PM
Resident German Group: Admin Posts: 41,675 Joined: 21-January 03 From: Oakland, Kalifornia Member No.: 179 Region Association: Northern California |
make sure it's not cracked. (IMG:style_emoticons/default/sad.gif)
they do that from time to time ... take it off and check it for cracks, Andy |
415PB |
Feb 5 2004, 06:45 PM
Thanks Andy, I will do that now, but how about the 1104?
SirAndy |
Feb 5 2004, 06:49 PM
QUOTE(415PB @ Feb 5 2004, 04:45 PM) Thanks Andy, I will do that now, but how about the 1104? don't know cause i don't know what 1104 is ... <_< |
Brad Roberts |
Feb 5 2004, 07:06 PM
914 Freak! Group: Members Posts: 19,148 Joined: 23-December 02 Member No.: 8 Region Association: None |
The 2.0 intake plenum cracks around the two supports that are brazed into the center just to the outside of the actual base for the throttle body. They break because most people dont know that they should adjust the throttle stop below the gas pedal... every time you floor it it pulls on the throttle body and will crack the plenum if not adjusted properly.
B |
415PB |
Feb 5 2004, 07:55 PM
The throttle body appears okay with no cracks. I will check the plenum now. As far as sealing the throttle body back to the plenum. Would it be okay to use a sealant instead of the gasket?
Bleyseng |
Feb 5 2004, 08:05 PM
Aircooled Baby! Group: Members Posts: 13,035 Joined: 27-December 02 From: Seattle, Washington (for now) Member No.: 24 Region Association: Pacific Northwest |
Yes, plus check the throttle shaft for slop. The damn things can leak real bad if worn out. Before reinstalling the TB sand it flat cuz they get warped from overtighting.
Geoff |
Brad Roberts |
Feb 5 2004, 08:10 PM
Use sealant on the gasket.. no reason not to use the gasket. It has worked well for 30+ years now.
B |
415PB |
Feb 5 2004, 09:00 PM
Okay, I used the sealant on the old gasket and it works great. Meaning it no longer hunts. It warms up at 1700 RPM then when the AAR kicks off it idles at 1200 RPM. The idle adjustment screw is turned in almost all the way and when turned out the idle rises. I played a little with the adjustment on the ECU but it makes no difference. The AAR is shutting off, I checked this when warm and it is not sucking air. Any ideas? The Decel valve is plugged and I dont know where is to look.
Brad Roberts |
Feb 5 2004, 09:03 PM
You have multiple leaks in multiple area's. The one that has kicked my butt most often... the PCV valve on the oil filler. If it leaks.. or is broken... it can/will mislead you.
B |
Bleyseng |
Feb 6 2004, 12:40 AM
Do you have the vacuum retard and vacuum advance hoses hooked up right?
Is the timing set to 27degrees btdc? Hoses off and plugged when checking witha light. Geoff |
Lo-Fi Version | Time is now: 7th June 2024 - 05:31 AM |
