70 side shift conversion, Need a boot at the firewall |
r_towle |
Sep 28 2008, 09:27 AM
Custom Member Group: Members Posts: 24,585 Joined: 9-January 03 From: Taxachusetts Member No.: 124 Region Association: North East States |
So,
I did this on my 72 years ago after fighting with the tail shifter for a few years. My setup is using the sidshifter boot, but it has nothing to seal against at the firewall so it mainly just gets in the way... Did anyone come up with a decent solution to protect that cone screw/u-joint??? Rich |
SLITS |
Sep 28 2008, 09:33 AM
"This Utah shit is HARSH!" Group: Benefactors Posts: 13,602 Joined: 22-February 04 From: SoCal Mountains ... Member No.: 1,696 Region Association: None |
I never did ... just left it exposed. I suppose you could screw the boot to the firewall.
So.Cal.914 |
Sep 28 2008, 09:52 AM
"...And it has a front trunk too." Group: Members Posts: 6,588 Joined: 15-February 04 From: Low Desert, CA./ Hills of N.J. Member No.: 1,658 Region Association: None |
Cap'n Krusty |
Sep 28 2008, 10:06 AM
My first employment at an independent shop was At Porschop in LA. The bosses were well known innovators and "fixers" rather than parts changers. We did a side shift conversion in 1974. Vern Covert made a flange for the boot by welding tabs on an old 356 rear main bearing (cut in half) and affixed it to the firewall. The boot slipped right over it. If you can TIG weld, I think I can supply you with a used bearing.
The Cap'n |
r_towle |
Sep 28 2008, 10:44 AM
My first employment at an independent shop was At Porschop in LA. The bosses were well known innovators and "fixers" rather than parts changers. We did a side shift conversion in 1974. Vern Covert made a flange for the boot by welding tabs on an old 356 rear main bearing (cut in half) and affixed it to the firewall. The boot slipped right over it. If you can TIG weld, I think I can supply you with a used bearing. The Cap'n So the fix is to make a flange like a 74...ok we can do that while the tub is stripped for Rockets new car... I may be able to just remove the flange on his car...gotta go take a look. I like having that boot, it keeps the cone screw from falling on the street... Also keeps the lube in there. I can make a flange or like you said, use a bearing...I have a few. I was hoping someone came up with a simple boot from some other car that worked...oh well. Rich |
Phoenix-MN |
Sep 28 2008, 11:10 AM
Senior Member Group: Members Posts: 927 Joined: 23-January 04 From: ST. Bonifacius,MN Member No.: 1,590 |
Aug 1990 issue of Porsche Panorama covered this. I just made the parts for mine (Some dimensions were not correct) but it works well
Paul |
r_towle |
Sep 28 2008, 02:23 PM
That should be in my upderfixen porsche books...any idea which volume that may be??? I suppose I could look through the index...hmmm
Rich Aug 1990 issue of Porsche Panorama covered this. I just made the parts for mine (Some dimensions were not correct) but it works well Paul |
Phoenix-MN |
Sep 28 2008, 05:18 PM
"That should be in my upderfixen porsche books...any idea which volume that may be??? I suppose I could look through the index...hmmm
Rich" I'm not sure what upfix'n volume it would be in, I guess it would be the one that covered Pano issues for 1990. The dimensions for the eliptical plate are off and you will need to trim it to fit (like the article states). The three washers you cut should be: 2.75" O.D 1.5" I.D (qty 1) 2.00" O.D. 1.5" I.D. (qty 2) I found these dimensions to fit the boot much better. I used .190 aluminum sheet to make the parts. Paul |
Lo-Fi Version | Time is now: 3rd June 2024 - 05:30 AM |
