Thanks to Mike Z, it's the little things |
Queenie |
Feb 6 2004, 03:44 PM
Society Is A Hole Group: Members Posts: 383 Joined: 14-July 03 From: SLO-CA Member No.: 908 |
You recommended some time back that I switch from multi-viscosity oil to single in order to cut down some on the oil burning problem ... and I'll be damned if it hasn't made a noticeable difference! It does still burn some - it's not like the problem was magically solved or anything - but it's definitely better than it was.
Also, you had mentioned wanting to possibly make a poster from one of the 914 pictures I posted - the 9 repeating images, if I recall correctly? That's certainly ok by me. Let me see how good a scan I can get out of it, and I'll send it to you on disc if you still want it. |
Joe Bob |
Feb 6 2004, 04:46 PM
Retired admin, banned a few times Group: Members Posts: 17,427 Joined: 24-December 02 From: Boulder CO Member No.: 5 Region Association: None |
Bueno....glad it worked out. What did you end up using? Straight 40 or higher?
Queenie |
Feb 6 2004, 05:30 PM
We went with straight 30, figuring if the car ran like shit we could always just drain it and start over. It seems to be real happy, though.
Lo-Fi Version | Time is now: 7th June 2024 - 02:50 AM |
