Alternatives Using Stock Steering Wheel |
7TPorsh |
Oct 3 2008, 02:13 PM
7T Porsh Group: Members Posts: 2,691 Joined: 27-March 06 From: Glendale Ca Member No.: 5,782 Region Association: Southern California |
i have a decent wheel that I can probably sew a wrap on and refinish the spokes...justthe center horn assembly doesn't go straight; it's like 45 degrees off from the wheel spokes and no matter how I try to screw it on it ends up off.
The thing is ugly too...so I saw a wheel once that was a stock wheel with a round center cover. Is there any wheel I can use without getting a hub? or it there anything I can do to the stock wheel to make it work and look better? Not too concerned about a horn; have another push button on the dash. Thanks |
r_towle |
Oct 3 2008, 02:16 PM
Custom Member Group: Members Posts: 24,585 Joined: 9-January 03 From: Taxachusetts Member No.: 124 Region Association: North East States |
Super beetle and 356 c and sc have the same splines on the hub that mounts to the steering shaft. So, they fit with no hub.
That opens it up a bit for shopping. You can also get a grant wheel... Rich Attached thumbnail(s) |
7TPorsh |
Oct 3 2008, 07:09 PM
Super beetle and 356 c and sc have the same splines on the hub that mounts to the steering shaft. So, they fit with no hub. That opens it up a bit for shopping. You can also get a grant wheel... Rich So wheels for a Super Beetle or 356 c,sc would work with the existing hub? Probably nothing nicer there. The grant has a splined hole that bolts directly to the 914 hub? (IMG:style_emoticons/default/blink.gif) Is that a Grant above? looks like a Nardi...and it looks like you have a different hub. |
r_towle |
Oct 3 2008, 07:15 PM
My wheel has a momo hub its a motolita copy.
Look on ebay...made and sold in Japan. The 356 C and SC, not the A or PreA have the same splines on the steering shaft. The wheel fits no hub... You will need to figure out blinkers and see if they hit... The thing to think about is this. Take off your wheel, turn it over...look at the part that is riveted onto the wheel...that part can and does come off the wheel. The same part is on a late beetle wheel (cheaper to get) That part allows you to buy ANY wheel...that is your hub. BTDT many times with wheels for 356 or 914 cars. Drill out the rivets, machine the next wheel to accept the part. Rich |
Todd Enlund |
Oct 3 2008, 07:54 PM
Resident Photoshop Guru Group: Members Posts: 3,251 Joined: 24-August 07 From: Laurelhurst (Portland), Oregon Member No.: 8,032 Region Association: Pacific Northwest |
Early 911 has the same splines too, but the wheels won't fit.
ClayPerrine |
Oct 3 2008, 11:06 PM
Life's been good to me so far..... Group: Admin Posts: 15,503 Joined: 11-September 03 From: Hurst, TX. Member No.: 1,143 Region Association: NineFourteenerVille |
Early 911 has the same splines too, but the wheels won't fit. Yes, it will. The only difference is the tapered plastic piece that attaches to the back of the wheel. It is made to adapt the 911 wheel to the VW column. All you do is take off the 911 cancel cam, and replace it with the tapered plastic piece. Been there, done that! |
Lo-Fi Version | Time is now: 3rd June 2024 - 06:54 AM |
