Questions for the pros |
LeNoah |
Oct 3 2008, 05:14 PM
Newbie Group: Members Posts: 35 Joined: 5-September 08 From: the OC Member No.: 9,515 Region Association: Southern California |
A couple quick qustions for you seasoned teeners from a newbie.
I changed out the broken ext door handles and put in the old lock cylinders. All works fine but there is a small, very thin bushing/washer that goes around the cylinder bfore it goes back into the mechanism. Everyone I have seen falls apart in pieces when the cylinder is removed. Is there any source for that part? Or a substitute/work around? Headlights work in low beam but go dark when I hit high beams. New bulbs? A relay? Switch? Can I buy a pair of halogens (lots of 'em on ebay) and just plug & play or do they require other mods? Thanks for the help. LN (IMG:style_emoticons/default/idea.gif) |
ws91420 |
Oct 3 2008, 05:21 PM
Yes I have one a Lensley 914 Group: Members Posts: 2,063 Joined: 10-September 03 From: Ruther Glen,VA (halfway between sticks and civilization) Member No.: 1,137 Region Association: MidAtlantic Region |
Check Pelican or Auto Atlanta for the bushing. For the lights check fuses first, then relays. H6054 bulbs will hook up fine.
SGB |
Oct 3 2008, 09:55 PM
just visiting Group: Members Posts: 4,086 Joined: 8-March 03 From: Huntsville, AL Member No.: 404 Region Association: South East States |
I dunno about the lock cylinders thing. The headlight thing is almost certainly a bad high beam relay, under the dash to the left of the steering wheel, on the side of the fuse panel. I
dbgriffith75 |
Oct 4 2008, 06:32 AM
TheGrif Group: Members Posts: 509 Joined: 25-July 07 From: Iowa, USA Member No.: 7,945 Region Association: Upper MidWest |
1.Remove the lock cylinder and handle entirely and just use a screwdriver to open your door.
2. Secure LED MAG lights to your hood with duct tape. Problems solved. ;D |
Lo-Fi Version | Time is now: 7th June 2024 - 05:20 AM |
