A couple quick qustions for you seasoned teeners from a newbie.
I changed out the broken ext door handles and put in the old lock cylinders. All works fine but there is a small, very thin bushing/washer that goes around the cylinder bfore it goes back into the mechanism. Everyone I have seen falls apart in pieces when the cylinder is removed. Is there any source for that part? Or a substitute/work around?
Headlights work in low beam but go dark when I hit high beams. New bulbs? A relay? Switch? Can I buy a pair of halogens (lots of 'em on ebay) and just plug & play or do they require other mods?
Thanks for the help.
LN
