Questions for the pros |
LeNoah |
Oct 3 2008, 05:14 PM
Newbie Group: Members Posts: 35 Joined: 5-September 08 From: the OC Member No.: 9,515 Region Association: Southern California |
A couple quick qustions for you seasoned teeners from a newbie.
I changed out the broken ext door handles and put in the old lock cylinders. All works fine but there is a small, very thin bushing/washer that goes around the cylinder bfore it goes back into the mechanism. Everyone I have seen falls apart in pieces when the cylinder is removed. Is there any source for that part? Or a substitute/work around? Headlights work in low beam but go dark when I hit high beams. New bulbs? A relay? Switch? Can I buy a pair of halogens (lots of 'em on ebay) and just plug & play or do they require other mods? Thanks for the help. LN (IMG:style_emoticons/default/idea.gif) |
Lo-Fi Version | Time is now: 17th May 2024 - 08:59 AM |
