Going to Dual Carbs, Could be a newbie question |
turnaround89 |
Dec 5 2008, 12:09 PM
Senior Member Group: Members Posts: 671 Joined: 17-May 08 From: Rockford, Illinois Member No.: 9,067 Region Association: Upper MidWest |
I just bought the Empi 40 HPMX dual carb kit and had a question about them. The single carb has an electric choke and the dual carbs do not have an electric choke like the single carb. Am i missing something or is this how dual carbs are set up?
ws91420 |
Dec 5 2008, 12:29 PM
Yes I have one a Lensley 914 Group: Members Posts: 2,063 Joined: 10-September 03 From: Ruther Glen,VA (halfway between sticks and civilization) Member No.: 1,137 Region Association: MidAtlantic Region |
no electric choke on duals
rhodyguy |
Dec 5 2008, 01:00 PM
Chimp Sanctuary NW. Check it out. Group: Members Posts: 22,082 Joined: 2-March 03 From: Orion's Bell. The BELL! Member No.: 378 Region Association: Galt's Gulch |
the fuel enrichment/high startup idle device is to the right of the brake pedal.
IronHillRestorations |
Dec 5 2008, 01:16 PM
I. I. R. C. Group: Members Posts: 6,720 Joined: 18-March 03 From: West TN Member No.: 439 Region Association: None |
No choke, and you won't need it. Use your foot as fast idle until your engine warms up.
So.Cal.914 |
Dec 5 2008, 01:24 PM
"...And it has a front trunk too." Group: Members Posts: 6,588 Joined: 15-February 04 From: Low Desert, CA./ Hills of N.J. Member No.: 1,658 Region Association: None |
the fuel enrichment/high startup idle device is to the right of the brake pedal. (IMG:style_emoticons/default/av-943.gif) My duels flood easy, one pump in the morning before you attempt to start it. When it fires then you do a Rhodyguy and keep the R's up till warm. (IMG:style_emoticons/default/smile.gif) |
turnaround89 |
Dec 5 2008, 02:13 PM
Wow, so thats what that enrichment thing does that has the cover on it. thanks everybody. When i try to start the car ill just have to pump the gas pedal, i have to do that anyway with the single carb. Thanks again!!!!!
Lo-Fi Version | Time is now: 23rd May 2024 - 11:20 AM |
