Hey Subie guys..., Alternator belt? |
malaga_red75 |
Dec 17 2008, 11:21 PM
'74 2.5L N/A Subie Group: Members Posts: 454 Joined: 5-March 06 From: Menlo Park, CA Member No.: 5,674 Region Association: None |
So i will not be replacing the A/C pump or the power steering pump...so what custom belt have you been using to drive the alternator? Is it from another car? Where can I get one? Thanks in advance.
-Peter |
914helo |
Dec 17 2008, 11:39 PM
Member Group: Members Posts: 235 Joined: 29-September 04 From: Southern Utah Member No.: 2,859 Region Association: None |
On my SVX conversion I kept the belt tensioner below the power steering bracket and put it about in the middle of the adjustment range. Count the # of ribs (usually 4 or 5) and measure with a string how long of a belt you will need. My local Carquest let me dig around the belts for a 5 rib that is ___ inches long. In the spring I hope to be adding AC. (IMG:style_emoticons/default/aktion035.gif)
TonyAKAVW |
Dec 18 2008, 04:26 PM
That's my ride. Group: Members Posts: 2,151 Joined: 17-January 03 From: Redondo Beach, CA Member No.: 166 Region Association: None |
I flipped my alternator around so it may not be the same as what you need, but I just took a measurement with the old belt that I had cut, and went to Pep Boys and did the same as Kent.
plymouth37 |
Dec 18 2008, 04:56 PM
Senior Member Group: Members Posts: 1,825 Joined: 24-May 05 From: Snoqualmie, WA Member No.: 4,138 Region Association: Pacific Northwest |
On my 2004 WRX engine with no A/C or PS I am running a Goodyear Gatorback alternator belt Part number 4050272-5PK690.
malaga_red75 |
Dec 19 2008, 01:17 AM
Cool, Thanks guys...I think I will check for a gatorback since my alternator will still be in the stock location.
-Peter |
budman5201 |
Dec 26 2008, 09:06 AM
Senior Member Group: Members Posts: 595 Joined: 1-April 07 From: tempe, az Member No.: 7,635 |
Cool, Thanks guys...I think I will check for a gatorback since my alternator will still be in the stock location. -Peter 27.5 inch belt 4 or 5 rib. 5 rib will be hard to come by, but the 4 rib is Common. Attached image(s) |
malaga_red75 |
Jan 2 2009, 11:14 PM
I went on Summit and found a 5 rib gatorback at 27.25in or a 4 rib gatorback at 27.5in. What is more important...being 27.5in or having 5 ribs?
Thanks in advance. -Peter |
Lo-Fi Version | Time is now: 10th June 2024 - 08:19 PM |
