CIS 3.0L install tips and tricks wanted |
Nana's_914 |
Jan 3 2009, 09:20 PM
Member Group: Members Posts: 98 Joined: 27-October 06 From: San Diego, CA Member No.: 7,100 Region Association: Southern California |
I am very close to starting on my 6 conversion. (IMG:style_emoticons/default/drooley.gif)
I have a decent inventory of parts now. Many of the parts are from my '77/'78 911SC hybrid donor car. I've seen that many folks ditch the CIS for carbs, but I would like to keep the CIS if I can. I've heard about CIS interference issues requiring latch relocation and using banjo fuel lines to clear the trunk side of the engine bay. Are there any adjustments to mount locations needed to make the motor fit without cutting the car? What other surprises may I be in for? Some of the parts I am using are RJ bulkhead mount, a WEVO 915, DW oil tank, and MSDS headers. Parts I still need are engine tins, oil lines(hoping to mod the 911 lines), and chassis reinforcement. Parts recommendations welcome. Thanks |
SLITS |
Jan 3 2009, 09:51 PM
"This Utah shit is HARSH!" Group: Benefactors Posts: 13,602 Joined: 22-February 04 From: SoCal Mountains ... Member No.: 1,696 Region Association: None |
Rich calls for an installed height of 7" on his mount. It is possible that you may be able to lower it to 6.5" so the fuel distributor will clear. Give him a call and see what he thinks. It's what I'm going to do on my next one.
I also cut the trunk torsion bars out and used the shock kit. I just cut the engine latch off and used hood pins on each side. Racing bling ya know. You do know that if you want to use a 914 transmission you have to acquire a '70-'71 901/911 transmission** or have Kennedy make you a flywheel out of a type 4 or early 901 flywheel. 6 bolt thru the 2.7L and yours is 9 bolt. That's why I stay with the 2.7L even though I do have a 3.0L. Maybe there is another way of doing it, but I ain't that smart or have enough money. ** Clutch kit for this transmission is $800. You will have to install the front engine tin after you have the engine installed. It won't clear the mount when installing the engine. Well, that's my experience anyway. |
scotty b |
Jan 3 2009, 09:56 PM
rust free you say ? Group: Members Posts: 16,375 Joined: 7-January 05 From: richmond, Va. Member No.: 3,419 Region Association: None |
Some of the parts I am using are RJ bulkhead mount, a WEVO 915, DW oil tank, and MSDS headers. Parts I still need are engine tins, oil lines(hoping to mod the 911 lines), and chassis reinforcement. Parts recommendations welcome. Thanks Step away from the J Gumby (IMG:style_emoticons/default/poke.gif) (IMG:style_emoticons/default/laugh.gif) |
Nana's_914 |
Jan 3 2009, 10:06 PM
Rich calls for an installed height of 7" on his mount. It is possible that you may be able to lower it to 6.5" so the fuel distributor will clear. Give him a call and see what he thinks. It's what I'm going to do on my next one. I also cut the trunk torsion bars out and used the shock kit. I just cut the engine latch off and used hood pins on each side. Racing bling ya know. You do know that if you want to use a 914 transmission you have to acquire a '70-'71 901/911 transmission** or have Kennedy make you a flywheel out of a type 4 or early 901 flywheel. 6 bolt thru the 2.7L and yours is 9 bolt. That's why I stay with the 2.7L even though I do have a 3.0L. Maybe there is another way of doing it, but I ain't that smart or have enough money. ** Clutch kit for this transmission is $800. You will have to install the front engine tin after you have the engine installed. It won't clear the mount when installing the engine. Well, that's my experience anyway. Thanks for the tips. You have CIS in yours? Any pics? As for trans... I just finished going through the trouble/expense of modifying the 915 with a WEVO side shift kit and a Guards Club 40/60 LSD. |
SLITS |
Jan 3 2009, 10:14 PM
Yeh, Scotty nailed me on the tranny .... guess I don't read with comphrension. (IMG:style_emoticons/default/biggrin.gif)
I sold the first conversion and do not have images of it. The second conversion is on the back burner so I don't have any images. I used CIS on both cars. Wish I could help you. |
GeorgeRud |
Jan 3 2009, 10:15 PM
Advanced Member Group: Members Posts: 3,725 Joined: 27-July 05 From: Chicagoland Member No.: 4,482 Region Association: Upper MidWest |
The modified 915 should bolt right up to your 3.0 liter, that's what it mated with originally in the 911, so no problems there. You'll like the 915 gearbox, it shifts nicely as long as you don't try to speed shift too often. Changing to the rear trunk strut kit will gain you a bit of room at the back of the engine compartment, and makes for a nice, clean install (actually a whole lot nicer than the torsion springs). It should be possible to relocate the engine hood latch, but the hood pin idea is not a bad one.
When it's all in, you should have a nice setup. You might also check with George Hussey (Dr914 @ Auto Atlanta) as I believe he has this same setup in one of his cars. |
scotty b |
Jan 3 2009, 10:18 PM
Is the 915 superior enough to a side shifter to warrant the expense ? I have both and have debated whether or not to use the 915 in the 914 or hold on to it until if and when I get an early 911 to build (IMG:style_emoticons/default/confused24.gif)
Nana's_914 |
Jan 3 2009, 10:40 PM
Is the 915 superior enough to a side shifter to warrant the expense ? I have both and have debated whether or not to use the 915 in the 914 or hold on to it until if and when I get an early 911 to build (IMG:style_emoticons/default/confused24.gif) For me yes. For others maybe not. My 901 needed a rebuild and I wasn't interested in spending anything on it. I really didn't want to live with the shortcomings of the 901 anymore. |
Justinp71 |
Jan 3 2009, 10:53 PM
Senior Member Group: Members Posts: 1,584 Joined: 11-October 04 From: Sacramento, CA Member No.: 2,922 Region Association: None |
You can flip the whole CIS system and have the airbox on the firewall side, I have seen it done, but you need to modify the engine shroud.
Also you will need a 6pin CDI or an MSD setup. |
Nana's_914 |
Jan 3 2009, 11:01 PM
pete-stevers |
Jan 4 2009, 03:39 PM
saved from fire! Group: Members Posts: 2,642 Joined: 10-October 04 From: Abbotsford,BC, Canada Member No.: 2,914 Region Association: Pacific Northwest |
the problems i ran into with my 3.0 install was the cis was to tall
so i dropped the engine mount by about one inch including the tranny.(on Eric Shea's recomendations) deleting the breather hole on the back of the rubber boot attop the intake and against the wishes of the purists and the paranoid i cut a hole in the fire wall for timing and belt replacement and you will need to cut the engine lid latch off. relocate it if you choose to keep it with dropping the engine the shift rod will need to be modified, and the rj engine mount will need to be ground a bit for clearance( on the engine side) skip the idea of trying to turn the intake around...if you want to go to that length you should just do carbs. there are plenty of cis converted cars with the cis in its stock location |
r_towle |
Jan 4 2009, 03:45 PM
Custom Member Group: Members Posts: 24,586 Joined: 9-January 03 From: Taxachusetts Member No.: 124 Region Association: North East States |
Is the 915 superior enough to a side shifter to warrant the expense ? I have both and have debated whether or not to use the 915 in the 914 or hold on to it until if and when I get an early 911 to build (IMG:style_emoticons/default/confused24.gif) OK First...you wont get an early 911 to build...face it. Second...BEETLE...dont waste it on a 914....seriously Its as tempermental (if not more so ) than a 901. Rich |
scotty b |
Jan 4 2009, 03:52 PM
OK First...you wont get an early 911 to build...face it. Rich Says you, I know of 2 that are mine if I want them (IMG:style_emoticons/default/bootyshake.gif) BEETLE ?? Nah I've got a bus tranny in my baja (IMG:style_emoticons/default/slap.gif) |
r_towle |
Jan 4 2009, 04:01 PM
Hole in head!!!!
Find me an oval already....or at least a split roof clip... Rich |
scotty b |
Jan 4 2009, 04:54 PM
Hole in head!!!! Find me an oval already....or at least a split roof clip... Rich Yes that's why I haven't gotten either one. I have other projects I'd much rather do (IMG:style_emoticons/default/smile.gif) |
r_towle |
Jan 4 2009, 07:56 PM
Hole in head!!!! Find me an oval already....or at least a split roof clip... Rich Yes that's why I haven't gotten either one. I have other projects I'd much rather do (IMG:style_emoticons/default/smile.gif) Zactly... Now, hunt me down a split window roof clip.....please... Just the back window and vents... Rich |
iamchappy |
Jan 4 2009, 08:12 PM
It all happens so fast! Group: Members Posts: 4,893 Joined: 5-November 03 From: minnetonka, mn Member No.: 1,315 Region Association: Upper MidWest |
With some minor resurfacing, you can use the 3.0 flywheel with the 901, you will need a new starter ring , clutch, pressure plate and throw out bearing(I got my parts from Kennedy). The 901 is easily up to the task with a 180hp 3.0.
I had to shave the ribs on the rubber intake boot with mine and notch the back edge of the engine lid around the fuel distributor. I relocated the latch but later pinned it. I have the stock 6 mount, if i was mounting a new mount i would place it 3/4 to an inch lower to accomidate the engine height, and space down the tranny a little too. |
SLITS |
Jan 4 2009, 08:27 PM
You can flip the whole CIS system and have the airbox on the firewall side, I have seen it done, but you need to modify the engine shroud. Also you will need a 6pin CDI or an MSD setup. I haven't tried it yet, but I would think that you could rotate the fuel distributor to clear the fuel inlet lines from the rear firewall. Since it is constant injection, the position of the feeds shouldn't be important as to cylinder number. Just a thought. |
goose2 |
Jan 5 2009, 01:05 PM
Senior Member Group: Members Posts: 976 Joined: 30-March 05 From: Eugene, Oregon Member No.: 3,847 Region Association: Pacific Northwest |
I'm installing a 3.0 with CSI soon. I've collected a few pics of what others have done....may help:
Audi airbox used in the first 3 Attached image(s) |
goose2 |
Jan 5 2009, 01:12 PM
some more:
Attached image(s) |
Lo-Fi Version | Time is now: 6th June 2024 - 04:57 AM |
