Aftermarket ABS, Possible??? |
r_towle |
Jan 27 2009, 09:56 PM
Custom Member Group: Members Posts: 24,588 Joined: 9-January 03 From: Taxachusetts Member No.: 124 Region Association: North East States |
ABS (at least on my Volvo) is an independant ECU.
It relies upon four hall sensors, one on each wheel. Assuming the Hall sensors can be mounted properly and can be made to affectively send a signal, is there an aftermarket ECU system specifically for ABS brakes? Rich |
McMark |
Jan 27 2009, 10:04 PM
You need the ABS 'pump' and electric valves at each wheel. It wouldn't be too difficult, if you could get a stand-alone ECU working.
sww914 |
Jan 28 2009, 11:41 AM
Advanced Member Group: Members Posts: 2,439 Joined: 4-June 06 Member No.: 6,146 Region Association: None |
I'd be concerned about finding room for the trigger wheels out at the hubs. I think it's possible. PITA to find some trigger wheels that will fit that are also cheap.
turnaround89 |
Jan 28 2009, 12:23 PM
Senior Member Group: Members Posts: 671 Joined: 17-May 08 From: Rockford, Illinois Member No.: 9,067 Region Association: Upper MidWest |
You must do a lot of driving in the snow to want ABS (IMG:style_emoticons/default/biggrin.gif) . Sounds difficult, but WTH, go for it if you really want ABS.
jhadler |
Jan 28 2009, 12:40 PM
Long term tinkerer... Group: Members Posts: 1,879 Joined: 7-April 03 From: Lyons, CO Member No.: 529 |
You must do a lot of driving in the snow to want ABS (IMG:style_emoticons/default/biggrin.gif) . Sounds difficult, but WTH, go for it if you really want ABS. Have you autoxed a car with really good modern ABS? It's too cool! Just keep your foot in the go pedal way longer than you think you should, and then bury the woah pedal. And a really good system will even let you trail into a turn with the car staying perfectly poised and balanced. No lock up, no over rotation, just tuck right into the turn right up to the apex. Then it's right back onto the go pedal again... I've thought about it a number of times. It is a competitive advantage. Not that a non-ABS car can't do the same, but it's soooo much easier... (IMG:style_emoticons/default/biggrin.gif) If it wasn't a competitive advantage, why would F1 teams (among others) have tried to incorporate it into the cars before it was banned? -Josh2 |
J P Stein |
Jan 28 2009, 12:50 PM
Irrelevant old fart Group: Members Posts: 8,797 Joined: 30-December 02 From: Vancouver, WA Member No.: 45 Region Association: None |
turnaround89 |
Jan 28 2009, 02:43 PM
ABS would give an advantage in autox, but aren't people driving 914's in autox and winning without ABS, maybe they aren't, i don't really know. thats a complete guess.
How many types of racing banned ABS? 6-7k is a good chunk of change though. |
r_towle |
Jan 28 2009, 03:08 PM
You need the ABS 'pump' and electric valves at each wheel. It wouldn't be too difficult, if you could get a stand-alone ECU working. Aside from finding a specific ECU for this...which must be out there somewhere. I figured to pillage all the rest of the parts from a junkyard. Our rotors are pretty standard size if you look at alot of the smaller cars, volvo included. Yes, I do drive in the snow. I also Ice Race...ABS is awesome there. More interested in using it at an autox...it really allows you to brake later. Rich |
Joe Ricard |
Jan 28 2009, 03:15 PM
CUMONIWANNARACEU Group: Members Posts: 6,811 Joined: 5-January 03 From: Gautier, MS Member No.: 92 |
If it wasn't an advantage then most rule books would not have applied a weight penalty for it.
Like Josh said get a good one and it will help. Get a cheap one and you are just toting more tonnage. |
type11969 |
Jan 28 2009, 03:20 PM
Senior Member Group: Members Posts: 1,231 Joined: 2-December 03 From: Collingswood, NJ Member No.: 1,410 Region Association: North East States |
Is there a megasquirt type diy ecu for ABS? It would be worth asking over on the megasquirt board.
banger |
Jan 29 2009, 04:38 AM
Member Group: Members Posts: 354 Joined: 12-November 06 From: Santa Clarita Member No.: 7,205 Region Association: Southern California |
Most of the VW and Audi abs systems have the ecu built into the back of the pump. Basically you would need the abs pump unit, sensors and wiring harness. It shouldnt be too expensive to pick up a used unit.
ArtechnikA |
Jan 29 2009, 06:27 AM
rich herzog Group: Members Posts: 7,390 Joined: 4-April 03 From: Salted Roads, PA Member No.: 513 Region Association: None |
If it wasn't a competitive advantage, why would F1 teams (among others) have tried to incorporate it into the cars before it was banned? Because it's not about ABS, really, it's about traction control, and if you have an ECU that can independently control braking at each wheel, it's but a very simple and subtle hack to make that work like traction control (which is how it works in my Titan...) But the hard part is not the sensors and ECU - it's finding an ABS setup that was not designed to work with power brakes. Or finding a way to retrofit power brakes into a nonpower car. When Porsche finally went to power-assist brakes in the 911 they needed to make the move to suspended pedals - no more floor-mount pedal cluster. The vacuum booster gizmo is big. And you need to get vacuum to the front... |
Lo-Fi Version | Time is now: 8th June 2024 - 10:18 AM |
