1975 914 1.8 liter, Dual Relay and Resistor Carrier |
nigolusa |
Jan 30 2009, 02:38 PM
nigolusa Group: Retired Members Posts: 157 Joined: 10-November 08 From: los angeles Member No.: 9,737 Region Association: Southern California |
My idiot mechanic left these laying down.
An (IMG:style_emoticons/default/icon8.gif) ybody know where their locations are? Attached image(s) |
MartyYeoman |
Jan 30 2009, 02:43 PM
Senior Member Group: Members Posts: 1,520 Joined: 19-June 03 From: San Ramon, CA Member No.: 839 Region Association: Northern California |
Mount them anywhere you like.
Just organize the wires so they're happy. |
dr914@autoatlanta.com |
Jan 30 2009, 02:53 PM
914 Guru Group: Members Posts: 7,887 Joined: 3-January 07 From: atlanta georgia Member No.: 7,418 Region Association: None |
My idiot mechanic left these laying down. An (IMG:style_emoticons/default/icon8.gif) ybody know where their locations are? both mount on the side of the battery stand. Dr. 914 says that you MUST mount them there. |
Solo914 |
Jan 30 2009, 05:12 PM
Member Group: Members Posts: 266 Joined: 6-March 06 From: Redmond, WA Member No.: 5,678 Region Association: None |
My idiot mechanic left these laying down. An (IMG:style_emoticons/default/icon8.gif) ybody know where their locations are? both mount on the side of the battery stand. Dr. 914 says that you MUST mount them there. Yeah.. PITA. I have yet to put mine properly back where they belong. Anyone have a picture. Kyle |
jim_hoyland |
Jan 30 2009, 05:22 PM
Get that VIN ? Group: Members Posts: 9,315 Joined: 1-May 03 From: Sunset Beach, CA Member No.: 643 Region Association: Southern California |
My idiot mechanic left these laying down. An (IMG:style_emoticons/default/icon8.gif) ybody know where their locations are? FYI- If your 914 suddenly stops running (IMG:style_emoticons/default/sad.gif) check to see if that green band thats holding the relay broke and the relay is loose. It controls the fuel pump. If the green band is actually a locking wire tie, no problem. (IMG:style_emoticons/default/biggrin.gif) |
Solo914 |
Jan 30 2009, 05:27 PM
My idiot mechanic left these laying down. An (IMG:style_emoticons/default/icon8.gif) ybody know where their locations are? FYI- If your 914 suddenly stops running (IMG:style_emoticons/default/sad.gif) check to see if that green band thats holding the relay broke and the relay is loose. It controls the fuel pump. If the green band is actually a locking wire tie, no problem. (IMG:style_emoticons/default/biggrin.gif) Good advice. I found that one out the hard way. Kyle |
zonedoubt |
Jan 30 2009, 05:58 PM
Canadian Member Group: Members Posts: 668 Joined: 14-May 03 From: Vancouver, BC Member No.: 696 Region Association: Canada |
You can see them mounted below the battery here...
nigolusa |
Jan 31 2009, 08:48 AM
Can you please post a picture of the carbon canister mounting position.
Thanks so much!!!! (IMG:style_emoticons/default/type.gif) |
zonedoubt |
Jan 31 2009, 09:31 AM
Same photo shows the rough position. A clamp goes around the canister and mounts to the battery hold down bolt.
Can you please post a picture of the carbon canister mounting position. Thanks so much!!!! (IMG:style_emoticons/default/type.gif) You can see them mounted below the battery here... |
zonedoubt |
Jan 31 2009, 09:35 AM
I didn't have the original clamp so I bought a large gear clamp (5 to 6 inch diameter) and made a clamp that fits under the battery bolt.
Lo-Fi Version | Time is now: 3rd June 2024 - 10:56 AM |
