Dry sump or Simi-dri sump Cooling FOR A 914-4, not easy , but it's ness a sarry , if you want ac, dont get a 914 |
sam quartermain |
Feb 11 2009, 12:33 PM
The desire for glory is not a sin, TY COBB Group: Members Posts: 58 Joined: 2-February 09 From: monrovaia ca/ tarzana ca Member No.: 10,011 Region Association: None |
Is it possible to use a Dry sump setup for a 914-4 I'd like to try it cause I think it would make the car a lot more reliable. Is over heating in issue with 914's in so cal . ??? How hard would it be and where would i even start ? Attached image(s) |
GeorgeRud |
Feb 11 2009, 12:45 PM
Advanced Member Group: Members Posts: 3,725 Joined: 27-July 05 From: Chicagoland Member No.: 4,482 Region Association: Upper MidWest |
One of the VW type 4 suppliers did make a dual stage oil pump for the 914 motor, whick allows it to be dry sumped. I don't remember the manufacturer right now, but it has been done.
If you're running hot, perhaps an external auxiliary oil cooler would do more good than going through all the trouble and expense of converting to a dry sump system. |
Gint |
Feb 11 2009, 06:00 PM
Mike Ginter Group: Admin Posts: 16,082 Joined: 26-December 02 From: Denver CO. Member No.: 20 Region Association: Rocky Mountains |
Anything is possible. But how is converting a 914 type IV to dry sump going to make it a "lot more reliable"?
McMark |
Feb 11 2009, 08:39 PM
The issue will be the depth of the oil pump vs. the impeller housing. Not much room there.
Searching for "+dry +sump +pump" here got me this thread where we talk about it. |
SirAndy |
Feb 11 2009, 08:47 PM
Resident German Group: Admin Posts: 41,669 Joined: 21-January 03 From: Oakland, Kalifornia Member No.: 179 Region Association: Northern California |
But how is converting... to dry sump going to make it a "lot more reliable"? (IMG:style_emoticons/default/agree.gif) If in good working order, the T4 does not need any modifications to run smooth and cool. Even in "SlowCal" ... If your engine is running hot, you've got other problems! (IMG:style_emoticons/default/shades.gif) Andy |
Dominic |
Feb 11 2009, 09:17 PM
Dominic Group: Members Posts: 992 Joined: 14-January 03 From: Vacaville, CA Member No.: 149 Region Association: Northern California |
Is it possible to use a Dry sump setup for a 914-4 I'd like to try it cause I think it would make the car a lot more reliable. Is over heating in issue with 914's in so cal . ??? How hard would it be and where would i even start ? On the overheating issue, One place to start before you go external for oil cooling is the cooling fan shroud...make sure you dont have the lower opening of the shroud blocked off. I learned the hard way when I had those capped off since I was not using any heat off the exchangers. According to Jake you should leave those open and allow that air to escape from the bottom. Also, ensure you have your cooling flaps installed/working properly and that the air going to the stock oil cooler is not being blocked by leaves or debris. |
dlestep |
Feb 11 2009, 10:00 PM
I am smilin'... Group: Members Posts: 890 Joined: 15-January 08 From: Sunrise Florida Member No.: 8,573 Region Association: South East States |
...if you are worried, run an additional external cooler using the oil filter boss...
dry sumping will only free up a few horses at the upper rpms, which 99.99 percent of the time you won't be driving there...besides the two stage pump, even without the crank fan would be in interference with the front engine mount. You would be required to modify that just to install the pump and lines. I think that there was a discussion on that on Jake's site. |
LarryR |
Feb 11 2009, 10:08 PM
Senior Member Group: Members Posts: 929 Joined: 15-March 07 From: E. Bay Area, N. California Member No.: 7,604 |
The only reason I can think to dry sump a TIV is if you plan on doing serious racing and pulling mega g's in the corners...
The short answer is yes. My friends lola runs a TIV and it is dry sump so it is possible... I posted a similar question once and Jake said he has a solution. |
Lo-Fi Version | Time is now: 31st May 2024 - 09:45 PM |
