Heater System Question, Something Broke |
Britain Smith |
Feb 23 2004, 05:30 PM
Nano Member Group: Members Posts: 2,354 Joined: 27-February 03 From: Hillsboro, OR Member No.: 364 |
Well, I have my first 914 repair related question.
This morning the heater stopped blowing hot air into the cabin. I checked the fan in the engine bay to make sure it was working and it is still blowing hard. What other peices can I check? What does the little hand lever next the shifter actually move when you pull up on it? Anyone have any experience with this and can suggest a way to fix it? -Britain |
Jeroen |
Feb 23 2004, 05:53 PM
914 Guru Group: Members Posts: 7,887 Joined: 24-December 02 From: The Netherlands Member No.: 3 Region Association: Europe |
The lever operates the flappers on the heat exchangers
Maybe the cables are stuck or broken, or the flappers them selves are stuck... Good luck cheers, Jeroen |
mike_the_man |
Feb 24 2004, 11:38 AM
I like stuff! Group: Members Posts: 1,338 Joined: 11-June 03 From: Regina, Saskatchewan, Canada Member No.: 809 |
Crawl under the car and look at the heat exchangers. You'll see what looks like a vent on each one, with a little arm coming out of each one. (Is that clear?) There should be a cable attached to each arm. When you pull the red lever, it pulls the arms and opens the heater flaps. Have somebody operate the lever while you're under the car. you should be able to tell if they're working.
On my car, the cable was missing. I replaced it with a tandem bike brake cable. It was about $5 from the local bike shop. Once you're under there, everything should be pretty clear. |
Lo-Fi Version | Time is now: 13th June 2024 - 09:26 AM |
