Zerk fittings, Help with Zerk fittings install for front and rear bushings |
13b914 |
Mar 11 2009, 07:00 AM
Member Group: Members Posts: 75 Joined: 2-August 07 From: Youngstown Florida Member No.: 7,963 Region Association: None |
Does anyone have any detailed pictures of the zerk fitting install for the front and rear bushings. I tried the search function and came up with a few pictures but nothing real detailed. I would also like to know if the bushings are suppose to move around the rear trailing arm axle or is it suppose to be tight around the shaft. thanks in advance
charliew |
Mar 11 2009, 01:07 PM
Advanced Member Group: Members Posts: 2,363 Joined: 31-July 07 From: Crawford, TX. Member No.: 7,958 |
Check out the pictures of the ones done by the professionals. Racer Chris, etc.
Joe Ricard |
Mar 11 2009, 07:34 PM
CUMONIWANNARACEU Group: Members Posts: 6,811 Joined: 5-January 03 From: Gautier, MS Member No.: 92 |
Not much to it. drill a hole where it will be accessable tap it and put in the grease fitting. Obviously before putting the pivot shaft in.
Pay attention to the depth of the fitting make sure it doesn't protrude too far. |
RoadGlue |
Mar 11 2009, 09:00 PM
Sonoma County Gear Head Group: Admin Posts: 2,033 Joined: 8-January 03 From: Santa Rosa, CA Member No.: 108 Region Association: Northern California |
Does anyone have any detailed pictures of the zerk fitting install for the front and rear bushings. I tried the search function and came up with a few pictures but nothing real detailed. I would also like to know if the bushings are suppose to move around the rear trailing arm axle or is it suppose to be tight around the shaft. thanks in advance Oooh oooh, I do, I do! http://pixelrandy.zenfolio.com/p183342115 It's easy! |
13b914 |
Mar 12 2009, 04:12 AM
Does anyone have any detailed pictures of the zerk fitting install for the front and rear bushings. I tried the search function and came up with a few pictures but nothing real detailed. I would also like to know if the bushings are suppose to move around the rear trailing arm axle or is it suppose to be tight around the shaft. thanks in advance Oooh oooh, I do, I do! http://pixelrandy.zenfolio.com/p183342115 It's easy! Thank you very much, that is what I needed to see Chad |
913B |
Mar 25 2011, 05:03 PM
Senior Member Group: Members Posts: 847 Joined: 25-April 05 From: South Bay/SoCal Member No.: 3,983 Region Association: None |
Any chance I can see the pics ?
jmill |
Mar 25 2011, 05:30 PM
Green Hornet Group: Members Posts: 2,449 Joined: 9-May 08 From: Racine, Wisconsin Member No.: 9,038 Region Association: Upper MidWest |
Link is pwd protected. (IMG:style_emoticons/default/blink.gif)
Hint: You are a bot. (IMG:style_emoticons/default/confused24.gif) |
Lo-Fi Version | Time is now: 7th June 2024 - 07:57 PM |
