FS 21MM 5 hole spacers, 50mm & 65mm studs, More available Four spacers, 40 studs |
bdstone914 |
Apr 5 2009, 10:37 PM
bdstone914 Group: Members Posts: 4,533 Joined: 8-November 03 From: Riverside CA Member No.: 1,319 |
Update 4/17/09
I now have 2 more sets of spacers available and 2 sets of 65mm lugs. pricing is the same as below. the pictures below are not of the current spacers I have but look the same and are OEM Porsche. Still have a couple sets of studs in 65mm and 50 mm lenght. 50 mm lenght are for use with 1/4" spacers and the 65mm studs are for use with 3/4" = 21mm spacers. I have four sets of 21mm spacers and studs from 944 rear wheels. Spacers are $50 per pair. I have two pair. Only one pair is pictured. I also have forty 65mm studs which are the correct lenght to use with the spacers. Studs are $35 for a set of ten. Shipping is flat rate of $5 for as many studs as will fit in a flat rate envelope. Shipping for spacers with or without studs is $10. (IMG:http://img23.imageshack.us/img23/9217/dscf0938b.th.jpg) (IMG:http://img23.imageshack.us/img23/4410/dscf0939f.th.jpg) (IMG:http://img23.imageshack.us/img23/7209/dscf0940.th.jpg)[s] |
strawman |
Apr 6 2009, 09:35 AM
Senior Member Group: Members Posts: 881 Joined: 25-January 08 From: Los Osos, CA Member No.: 8,624 Region Association: Central California |
Are the studs OEM? Pelican shows either 67mm or 72mm. I imagine they're 67mm? Would you take Paypal as payment?
Geoff |
Derek Seymour |
Apr 6 2009, 05:49 PM
Member Group: Members Posts: 394 Joined: 10-March 09 From: Yucaipa Member No.: 10,151 Region Association: Southern California |
PM Sent
bdstone914 |
Apr 6 2009, 06:11 PM
bdstone914 |
Apr 18 2009, 09:00 AM
Update 4/17/09 Bump for more spacers available. I now have 2 more sets of spacers available and 2 sets of 65mm lugs. pricing is the same as below. the pictures below are not of the current spacers I have but look the same and are OEM Porsche. Still have a couple sets of studs in 65mm and 50 mm lenght. 50 mm lenght are for use with 1/4" spacers and the 65mm studs are for use with 3/4" = 21mm spacers. I have four sets of 21mm spacers and studs from 944 rear wheels. Spacers are $50 per pair. I have two pair. Only one pair is pictured. I also have forty 65mm studs which are the correct lenght to use with the spacers. Studs are $35 for a set of ten. Shipping is flat rate of $5 for as many studs as will fit in a flat rate envelope. Shipping for spacers with or without studs is $10. (IMG:http://img23.imageshack.us/img23/9217/dscf0938b.th.jpg) (IMG:http://img23.imageshack.us/img23/4410/dscf0939f.th.jpg) (IMG:http://img23.imageshack.us/img23/7209/dscf0940.th.jpg)[s] |
carr914 |
Apr 18 2009, 03:44 PM
Racer from Birth Group: Members Posts: 118,917 Joined: 2-February 04 From: Tampa,FL Member No.: 1,623 Region Association: South East States |
I'll take the studs. I will send you a pm
T.C. |
Lo-Fi Version | Time is now: 2nd June 2024 - 06:23 PM |
