WTB: Center gauge console |
ric birks |
Apr 17 2009, 11:11 PM
Newbie Group: Members Posts: 25 Joined: 19-December 08 From: Salem, Utah Member No.: 9,864 Region Association: Rocky Mountains |
Looking for a nice center console. Replacing the cut down A/C console unit in my car with a stock hight unit. Dont need the gauges. Any help will be welcomed. Thanks in advance, Ric.
jeeperjohn56 |
Apr 18 2009, 01:42 AM
Member Group: Members Posts: 479 Joined: 9-July 06 From: Antioch,Ca. Member No.: 6,407 Region Association: None |
Looking for a nice center console. Replacing the cut down A/C console unit in my car with a stock hight unit. Dont need the gauges. Any help will be welcomed. Thanks in advance, Ric. Ric, are you going to sell your cut down console? What are asking for it? I might be interested if it is cheap. John |
detoxcowboy |
Apr 18 2009, 12:15 PM
Senior Member Group: Members Posts: 1,294 Joined: 30-January 08 Member No.: 8,642 Region Association: Africa |
Looking for a nice center console. Replacing the cut down A/C console unit in my car with a stock hight unit. Dont need the gauges. Any help will be welcomed. Thanks in advance, Ric. You can make your own!! I have made 3 this version is for my personal set up but have made basic as well as a blank. You can get German Vinyl 1 yard will do it. Plywood, Hardware Etc.. I even Hand Stitched myself.. I had A.C. version too. All the center consoles out there are tired even the good ones.. 30 year old vinyl and plywwod does not hold up but I am sure there are "concourse ones out there" but most look out of place old in a new interior environment.. scuffs, tears, cig burns, loose or peeling stiching, cheap hardware.. etc.. Cracked wood hidden behind the vinyl.. Attached thumbnail(s) |
megfourfun |
Apr 18 2009, 07:24 PM
Newbie Group: Members Posts: 23 Joined: 20-February 09 From: Louisville, KY Member No.: 10,079 Region Association: None |
Looking for a nice center console. Replacing the cut down A/C console unit in my car with a stock hight unit. Dont need the gauges. Any help will be welcomed. Thanks in advance, Ric. You can make your own!! I have made 3 this version is for my personal set up but have made basic as well as a blank. You can get German Vinyl 1 yard will do it. Plywood, Hardware Etc.. I even Hand Stitched myself.. I had A.C. version too. All the center consoles out there are tired even the good ones.. 30 year old vinyl and plywwod does not hold up but I am sure there are "concourse ones out there" but most look out of place old in a new interior environment.. scuffs, tears, cig burns, loose or peeling stiching, cheap hardware.. etc.. Cracked wood hidden behind the vinyl.. I know you can buy them from AA with no center gauges but they will cost you. I noticed you said you hand stitched yours^. I need to redo the vinyl on mine but it looks like it was somehow heat sealed around the edges...any ideas on this? |
detoxcowboy |
Apr 19 2009, 08:01 PM
Looking for a nice center console. Replacing the cut down A/C console unit in my car with a stock hight unit. Dont need the gauges. Any help will be welcomed. Thanks in advance, Ric. You can make your own!! I have made 3 this version is for my personal set up but have made basic as well as a blank. You can get German Vinyl 1 yard will do it. Plywood, Hardware Etc.. I even Hand Stitched myself.. I had A.C. version too. All the center consoles out there are tired even the good ones.. 30 year old vinyl and plywwod does not hold up but I am sure there are "concourse ones out there" but most look out of place old in a new interior environment.. scuffs, tears, cig burns, loose or peeling stiching, cheap hardware.. etc.. Cracked wood hidden behind the vinyl.. I know you can buy them from AA with no center gauges but they will cost you. I noticed you said you hand stitched yours^. I need to redo the vinyl on mine but it looks like it was somehow heat sealed around the edges...any ideas on this? If your talking about the factory stitching it is my belief that the flatten the seem in a rolling press.. hard to do at home .. but if you realize function over form and can live without being concourse perfect then you can have a pretty nice interior with a little effort and thought.. does my console look bad?? I made it in my driveway.. AA's version you could build better yourself.. trust me (IMG:style_emoticons/default/stromberg.gif) (IMG:style_emoticons/default/headbang.gif) |
megfourfun |
Apr 20 2009, 12:17 PM
Looking for a nice center console. Replacing the cut down A/C console unit in my car with a stock hight unit. Dont need the gauges. Any help will be welcomed. Thanks in advance, Ric. You can make your own!! I have made 3 this version is for my personal set up but have made basic as well as a blank. You can get German Vinyl 1 yard will do it. Plywood, Hardware Etc.. I even Hand Stitched myself.. I had A.C. version too. All the center consoles out there are tired even the good ones.. 30 year old vinyl and plywwod does not hold up but I am sure there are "concourse ones out there" but most look out of place old in a new interior environment.. scuffs, tears, cig burns, loose or peeling stiching, cheap hardware.. etc.. Cracked wood hidden behind the vinyl.. I know you can buy them from AA with no center gauges but they will cost you. I noticed you said you hand stitched yours^. I need to redo the vinyl on mine but it looks like it was somehow heat sealed around the edges...any ideas on this? If your talking about the factory stitching it is my belief that the flatten the seem in a rolling press.. hard to do at home .. but if you realize function over form and can live without being concourse perfect then you can have a pretty nice interior with a little effort and thought.. does my console look bad?? I made it in my driveway.. AA's version you could build better yourself.. trust me (IMG:style_emoticons/default/stromberg.gif) (IMG:style_emoticons/default/headbang.gif) I actually like the stitched look of yours but dont think im up to it. My sowing in the past has come out pretty bad... I think the main difficult part are those rounded corners. |
detoxcowboy |
Apr 21 2009, 09:11 AM
Looking for a nice center console. Replacing the cut down A/C console unit in my car with a stock hight unit. Dont need the gauges. Any help will be welcomed. Thanks in advance, Ric. You can make your own!! I have made 3 this version is for my personal set up but have made basic as well as a blank. You can get German Vinyl 1 yard will do it. Plywood, Hardware Etc.. I even Hand Stitched myself.. I had A.C. version too. All the center consoles out there are tired even the good ones.. 30 year old vinyl and plywwod does not hold up but I am sure there are "concourse ones out there" but most look out of place old in a new interior environment.. scuffs, tears, cig burns, loose or peeling stiching, cheap hardware.. etc.. Cracked wood hidden behind the vinyl.. I am not a seamstress, just trace it inside out , follow the line.. turn it right side out when done, push the wood in tightly.. it is only thread and needle so adding some stitiching or pulling some out is no big deal.. just don't let you wife see you or you'll be making curtains this summer.. I know you can buy them from AA with no center gauges but they will cost you. I noticed you said you hand stitched yours^. I need to redo the vinyl on mine but it looks like it was somehow heat sealed around the edges...any ideas on this? If your talking about the factory stitching it is my belief that the flatten the seem in a rolling press.. hard to do at home .. but if you realize function over form and can live without being concourse perfect then you can have a pretty nice interior with a little effort and thought.. does my console look bad?? I made it in my driveway.. AA's version you could build better yourself.. trust me (IMG:style_emoticons/default/stromberg.gif) (IMG:style_emoticons/default/headbang.gif) I actually like the stitched look of yours but dont think im up to it. My sowing in the past has come out pretty bad... I think the main difficult part are those rounded corners. |
detoxcowboy |
Apr 21 2009, 09:15 AM
megfourfun |
Apr 21 2009, 12:58 PM
I am not a seamstress, just trace it inside out , follow the line.. turn it right side out when done, push the wood in tightly.. it is only thread and needle so adding some stitiching or pulling some out is no big deal.. just don't let you wife see you or you'll be making curtains this summer.. lol...sounds good. Ill start looking for a place to get the vinyl. |
detoxcowboy |
Apr 21 2009, 04:39 PM
I am not a seamstress, just trace it inside out , follow the line.. turn it right side out when done, push the wood in tightly.. it is only thread and needle so adding some stitiching or pulling some out is no big deal.. just don't let you wife see you or you'll be making curtains this summer.. lol...sounds good. Ill start looking for a place to get the vinyl. I used porsche 911 exterior grade leatherette, but there is more choices than that at pelican parts search all porsche.. vinyl. |
stutghaus |
Apr 22 2009, 01:44 PM
Newbie Group: Members Posts: 2 Joined: 22-April 09 From: Mooresville, NC Member No.: 10,289 Region Association: South East States |
Looking for a nice center console. Replacing the cut down A/C console unit in my car with a stock hight unit. Dont need the gauges. Any help will be welcomed. Thanks in advance, Ric. I have a center console FS (L&R side pieces, center shifter piece with one cigarette burn about the size of an eraser on a wooden pencil and the unique center console defroster lever) at $225. Bill |
detoxcowboy |
Apr 22 2009, 02:39 PM
Looking for a nice center console. Replacing the cut down A/C console unit in my car with a stock hight unit. Dont need the gauges. Any help will be welcomed. Thanks in advance, Ric. I have a center console FS (L&R side pieces, center shifter piece with one cigarette burn about the size of an eraser on a wooden pencil and the unique center console defroster lever) at $225. Bill I built mine for 75.00.. (IMG:style_emoticons/default/confused24.gif) |
Beamer13 |
Apr 22 2009, 09:20 PM
Member Group: Members Posts: 303 Joined: 8-November 07 From: Midwest Member No.: 8,308 Region Association: Upper MidWest |
I have for sale, a stock style Center Console. I had bought it thinking that I would add it to my teener, but ended up going a different direction. Anyway, it is the stock style (3 guage) console. The side closest to the driver has been rubbed through the vinyl and padding, and the passenger side has a crack in the vinyl. ( When I was going to put it in I fould vinyl fairly cheap at wal-mart in the fabric department) It has the switch for the rear defrost as well. $160 obo
ric birks |
Apr 28 2009, 06:52 PM
I have for sale, a stock style Center Console. I had bought it thinking that I would add it to my teener, but ended up going a different direction. Anyway, it is the stock style (3 guage) console. The side closest to the driver has been rubbed through the vinyl and padding, and the passenger side has a crack in the vinyl. ( When I was going to put it in I fould vinyl fairly cheap at wal-mart in the fabric department) It has the switch for the rear defrost as well. $160 obo |
rexer |
May 7 2009, 07:58 PM
Newbie Group: Members Posts: 1 Joined: 7-May 09 From: El Dorado Hills, CA Member No.: 10,344 Region Association: None |
edrotol |
May 8 2009, 06:00 PM
edrotol Group: Members Posts: 190 Joined: 23-April 06 From: Woburn, MA Member No.: 5,910 Region Association: North East States |
Looking for a nice center console. Replacing the cut down A/C console unit in my car with a stock hight unit. Dont need the gauges. Any help will be welcomed. Thanks in advance, Ric. Have one for sale on e-bay 9.5 out of 10 out of Winchester, MA Assembly, gauges, wiring harness. PM if interested. |
Lo-Fi Version | Time is now: 11th June 2024 - 09:22 PM |
