wheels, will they fit |
statesblue |
Apr 28 2009, 12:08 PM
Newbie Group: Members Posts: 24 Joined: 4-August 08 From: Chino Valley Az Member No.: 9,386 Region Association: Southwest Region |
I was wondering if early Pedrini wheels will fit a 75??????
PeeGreen 914 |
Apr 28 2009, 12:13 PM
Just when you think you're done...wait, there is more..lol Group: Members Posts: 10,219 Joined: 21-September 06 From: Seattle, WA... actually Everett Member No.: 6,884 Region Association: Pacific Northwest |
Yes they will
blitZ |
Apr 28 2009, 12:20 PM
Beer please... Group: Members Posts: 2,223 Joined: 31-August 05 From: Lawrenceville, GA Member No.: 4,719 Region Association: South East States |
Make sure you get a lug centric balance as they are lug centric wheels.
McMark |
Apr 28 2009, 12:45 PM
If they are TRUE early Pedrinis they will not fit. Early cars had what is referred to Lug-Centric wheel centering. Meaning the lug bolts were what centers the wheel on the hub/spindle. Starting in 72 (IIRC) 914s came with Hub-Centric wheel centering which means the wheel has a specially machine relief which perfectly fits over a raised portion in the hub/rotor and centers the wheel. Early Pedrinis do not have the hub-centric relief and will not fully seat on the hub. They will bolt up and to the untrained eye, they will look right, but they are a safety hazard and should not be used.
There are 1972 Pedrini's which have the relief and will work. |
SLITS |
Apr 28 2009, 12:54 PM
"This Utah shit is HARSH!" Group: Benefactors Posts: 13,602 Joined: 22-February 04 From: SoCal Mountains ... Member No.: 1,696 Region Association: None |
Look at the OE on the wheel.....
Ends in 00 .... early, won't fit late front hubs (lugcentric) Ends in 01 ... late, will fit late front hubs (hubcentric - center hole is bigger) |
sixnotfour |
Apr 28 2009, 01:34 PM
914 Wizard Group: Members Posts: 10,434 Joined: 12-September 04 From: Life Elevated..planet UT. Member No.: 2,744 Region Association: Rocky Mountains |
pictures and everything.....
http://www.914world.com/bbs2/index.php?s=&...t&p=1096069 |
statesblue |
Apr 28 2009, 03:58 PM
Thanks to all....
Can I change the rotors from the early to mine or is this not a good idea???? |
McMark |
Apr 28 2009, 04:34 PM
Early rotors have a different offset. Early rotor only work with early struts and early brake calipers.
You can machine the hub-centric ring off late rotors though. |
SLITS |
Apr 28 2009, 06:39 PM
Early rotors have a different offset. Early rotor only work with early struts and early brake calipers. You can machine the hub-centric ring off late rotors though. Or you can machine the early wheels to fit late rotors .......... What is it, raise the bridge or lower the water? |
Pat Garvey |
Apr 28 2009, 06:57 PM
Do I or don't I...........? Group: Members Posts: 5,899 Joined: 24-March 06 From: SE PA, near Philly Member No.: 5,765 Region Association: North East States |
Early rotors have a different offset. Early rotor only work with early struts and early brake calipers. You can machine the hub-centric ring off late rotors though. Or you can machine the early wheels to fit late rotors .......... What is it, raise the bridge or lower the water? The answer is this - bogus! So, why not fit a bogus wheel that will work without modification. They're out there. Why try to hide that fact that you aren't original? The gurus will know. The newbies won't. Wrong! Pat |
Lo-Fi Version | Time is now: 6th June 2024 - 06:24 AM |
