Fuel injector questions... |
jcambo7 |
May 7 2009, 08:28 PM
Senior Member Group: Members Posts: 1,664 Joined: 24-December 08 From: Graham, WA Member No.: 9,867 Region Association: Pacific Northwest |
So I was wondering if all fuel injectors are the same for 1.7, 1.8, and a 2.0 914 engine? Just curious if they are the same size for these engines or are they different sizes and they cannot be swapped to a different size engine? Also, should fuel injectors not have hose clamps where the hose connects to the fuel injector?
Thanks James |
SLITS |
May 7 2009, 10:37 PM
"This Utah shit is HARSH!" Group: Benefactors Posts: 13,602 Joined: 22-February 04 From: SoCal Mountains ... Member No.: 1,696 Region Association: None |
4 different flow rates, 2 different connectors, engine specific.
I suppose you could take a lower engine size injector and boost the fuel pressure to get a bit more juice. Hose and Norma clamps are best, but will run with regular hose clamps. Watch for leaks. Get either the German FI hose or something similar. 7mm mostly, 8mm feed to the pump. |
jcambo7 |
May 8 2009, 07:28 AM
4 different flow rates, 2 different connectors, engine specific. I suppose you could take a lower engine size injector and boost the fuel pressure to get a bit more juice. Hose and Norma clamps are best, but will run with regular hose clamps. Watch for leaks. Get either the German FI hose or something similar. 7mm mostly, 8mm feed to the pump. Thanks. I kind of figured they would all be different for each engine. |
zymurgist |
May 8 2009, 07:32 AM
"Ace" Mechanic Group: Members Posts: 7,411 Joined: 9-June 05 From: Hagerstown, MD Member No.: 4,238 Region Association: None |
Hose and Norma clamps are best, but will run with regular hose clamps. Watch for leaks. Get either the German FI hose or something similar. 7mm mostly, 8mm feed to the pump. (IMG:style_emoticons/default/agree.gif) I had leaks with US spec FI hose because it is slightly larger than the metric counterparts. You can't tighten the clamps enough to make it not leak. |
JeffBowlsby |
May 8 2009, 10:09 AM
914 Wiring Harnesses Group: Members Posts: 8,533 Joined: 7-January 03 From: San Ramon CA Member No.: 104 Region Association: None |
Attached thumbnail(s) |
Lo-Fi Version | Time is now: 8th June 2024 - 09:03 PM |
