Transmission Leak, Probably Pivot Bolt |
ThinAir |
May 21 2009, 01:53 AM
Best friends Group: Members Posts: 2,543 Joined: 4-February 03 From: Flagstaff, AZ Member No.: 231 Region Association: Southwest Region |
On the way to WCR my transmission started popping out of 5th gear and the bottom of the tranny was coated with oil. It looked like engine oil to me, but it turned out my transmission was totally out of oil.
The leak looks like it's coming from the bell housing. The engine oil level showed that it wasn't an engine oil leak. Since the clutch showed no signs of slippage, the only thing I can think of is the pivot bolt. I've searched, but can't find anything on this. I'm wondering what would cause oil to leak there and what to do about it. Anybody got any ideas or know of something else I should be checking? |
SirAndy |
May 21 2009, 03:55 PM
Resident German Group: Admin Posts: 41,661 Joined: 21-January 03 From: Oakland, Kalifornia Member No.: 179 Region Association: Northern California |
On the way to WCR my transmission started popping out of 5th gear and the bottom of the tranny was coated with oil. It looked like engine oil to me, but it turned out my transmission was totally out of oil. The leak looks like it's coming from the bell housing. The engine oil level showed that it wasn't an engine oil leak. Since the clutch showed no signs of slippage, the only thing I can think of is the pivot bolt. I've searched, but can't find anything on this. I'm wondering what would cause oil to leak there and what to do about it. Anybody got any ideas or know of something else I should be checking? Main shaft seal or pivot bolt. Take the pivot out, clean the area, use plenty of sealant and put it back in. If it's the main seal, you need to replace it. (IMG:style_emoticons/default/smash.gif) Andy |
McMark |
May 21 2009, 04:39 PM
Yup. Pull the tranny and do a complete reseal on it (IMHO). Not real complicated and you'll have the satisfaction of knowing the actual age of all those seals.
Drums66 |
May 21 2009, 04:54 PM
914 Rudiments Group: Members Posts: 5,321 Joined: 15-January 03 From: Coronado,Cali Member No.: 151 Region Association: Southwest Region |
*SHE BLEW*......tranny main seal (IMG:style_emoticons/default/blowup.gif)
ThinAir |
May 21 2009, 06:25 PM
Resealing the whole tranny was one idea that came to mind already and I think McMark is right about why that's a good idea.
Just to help my understanding of things, I was thinking that if it was the main seal I would have seen clutch problems because of oil all over the clutch disk. The pivot bolt came to mind as the one place that could dump oil into the bell housing without the oil getting on the clutch. Is there a flaw in that line of thinking? Andy - what kind of sealant do you use on the bolt? |
SirAndy |
May 21 2009, 06:28 PM
Is there a flaw in that line of thinking? The pivot bolt is right next to the main seal. Both will eventually get oil onto the clutch, but most of it will just drip down and out the bottom. I forget the brand of sealant i used. Ask McMark. If i recall correctly, it was white stuff. (IMG:style_emoticons/default/smash.gif) Andy |
Cap'n Krusty |
May 21 2009, 07:17 PM
Is there a flaw in that line of thinking? The pivot bolt is right next to the main seal. Both will eventually get oil onto the clutch, but most of it will just drip down and out the bottom. I forget the brand of sealant i used. Ask McMark. If i recall correctly, it was white stuff. (IMG:style_emoticons/default/smash.gif) Andy Red Loctite will seal it up just fine, "IF" you clean it properly. The Cap'n |
ThinAir |
May 21 2009, 11:17 PM
Thanks Cap'n!
Lo-Fi Version | Time is now: 28th May 2024 - 07:39 PM |
