starting to run right!, cable for heater flappers |
Ian Stott |
May 24 2009, 08:28 PM
Senior Member Group: Members Posts: 907 Joined: 28-January 08 From: Moncton/Canada Member No.: 8,635 Region Association: Canada |
Was away for the weekend and first thing I did when I got home was call my cool mechanic buddy! My car is far from done but wow what a difference so far, the complete engine gasket set, those little prebent high pressure hoses just before the injectors and new injector seals, valves adjusted properly and fresh oil and filter. What a difference, much quieter, smoother acceleration and noticeably more powerful. All dash lights and gauges now working, clock doesn't work though but the light does, buzzer cause key is still in the ignition works which I didn't know it had one! New 100 LB Weltmeister springs installed and shifter linkage adjusted so it shifts quite well, I feel like I am really making progress with the car and though there is a ton of stuff still to do it is at a level where you don't mind showing it off, my daughter is graduating next month and wants it for prom so I guess that is a big compliment! Next we will bleed the brakes and tackle the heat issue, I remember reading here not that long ago you could use a cable from a mountain bike for the heater flappers, anyone know about this??
Ian Stott Moncton Canada |
jaxdream |
May 24 2009, 09:21 PM
Senior Member Group: Members Posts: 974 Joined: 8-July 08 From: North Central Tennessee Member No.: 9,270 Region Association: South East States |
If it's stiff enough to push / pull the flapers , heater cables should not be that expensive to replace , how ever if the bike cable is long enough and stiff enough to operate reasonably well , I can't see any reason to not use them , if thats at hand and it works , go for it !!! Just remember the cables are no more than a stiff wire that is fed into the tubes that end real close to the flaper hookups and the lever pushes and pulls them according to what you want - heat or no heat. Try it .
Jaxdream |
echocanyons |
May 24 2009, 09:28 PM
Advanced Member Group: Benefactors Posts: 2,094 Joined: 24-December 02 From: Bay Area, CA Member No.: 7 Region Association: Central California |
I recently ordered the original part from porsche, it wasn't too expensive ~30 $ if I remember right.
If you make your own remember that they are not symmetrical. |
StratPlayer |
May 25 2009, 11:22 AM
StratPlayer Group: Members Posts: 3,278 Joined: 27-December 02 From: SLC, Utah Member No.: 27 Region Association: Rocky Mountains |
I'm pretty sure that AA sells those cables.
markb |
May 25 2009, 12:18 PM
914less :( Group: Members Posts: 5,449 Joined: 22-January 03 From: Nipomo, CA Member No.: 180 Region Association: Central California |
Actually, everybody can get them, since we all have to go to Porsche to order them (if we don't have them on the shelf).
Lo-Fi Version | Time is now: 23rd May 2024 - 01:15 AM |
