Was away for the weekend and first thing I did when I got home was call my cool mechanic buddy! My car is far from done but wow what a difference so far, the complete engine gasket set, those little prebent high pressure hoses just before the injectors and new injector seals, valves adjusted properly and fresh oil and filter. What a difference, much quieter, smoother acceleration and noticeably more powerful. All dash lights and gauges now working, clock doesn't work though but the light does, buzzer cause key is still in the ignition works which I didn't know it had one! New 100 LB Weltmeister springs installed and shifter linkage adjusted so it shifts quite well, I feel like I am really making progress with the car and though there is a ton of stuff still to do it is at a level where you don't mind showing it off, my daughter is graduating next month and wants it for prom so I guess that is a big compliment! Next we will bleed the brakes and tackle the heat issue, I remember reading here not that long ago you could use a cable from a mountain bike for the heater flappers, anyone know about this??
Ian Stott
Moncton
Canada
