Removing Smog Items, Will there be any issues? |
poorsche914 |
May 29 2009, 10:11 AM
T4 Supercharged Group: Members Posts: 3,090 Joined: 28-May 09 From: Smoky Mountains Member No.: 10,419 Region Association: South East States |
After nearly 20 years without a 914, I finally bought a daily driver (IMG:style_emoticons/default/driving.gif)
It is a California spec '75 2.0 with original FI. I plan on pulling all the smog equipment as well as replacing the heat exchangers and muffler with SS exchangers and a Bursch exhaust. Just wondering if there is anything that will need to be plugged, rerouted, etc with these changes. Thanks! |
ConeDodger |
May 29 2009, 10:18 AM
Apex killer! Group: Members Posts: 23,596 Joined: 31-December 04 From: Tahoe Area Member No.: 3,380 Region Association: Northern California |
After nearly 20 years without a 914, I finally bought a daily driver (IMG:style_emoticons/default/driving.gif) It is a California spec '75 2.0 with original FI. I plan on pulling all the smog equipment as well as replacing the heat exchangers and muffler with SS exchangers and a Bursch exhaust. Just wondering if there is anything that will need to be plugged, rerouted, etc with these changes. Thanks! The air injection ports will have to be plugged. Some people just pinch off and braze the ports at the head. I have recently seen an ad in the back of Excellence or Pano for a threaded block off. I think they might be NPT but not sure of the size. Truthfully though, biggest bang for the buck is to backdate that exhaust system. |
poorsche914 |
May 29 2009, 10:29 AM
thanks for the quick reply.
I think this weekend I will start by backdating the exhaust system as you suggested. The parts I have are from a '73 2.0. |
Cap'n Krusty |
May 29 2009, 10:43 AM
After nearly 20 years without a 914, I finally bought a daily driver (IMG:style_emoticons/default/driving.gif) It is a California spec '75 2.0 with original FI. I plan on pulling all the smog equipment as well as replacing the heat exchangers and muffler with SS exchangers and a Bursch exhaust. Just wondering if there is anything that will need to be plugged, rerouted, etc with these changes. Thanks! The air injection ports will have to be plugged. Some people just pinch off and braze the ports at the head. I have recently seen an ad in the back of Excellence or Pano for a threaded block off. I think they might be NPT but not sure of the size. Truthfully though, biggest bang for the buck is to backdate that exhaust system. The AIS pipes are 10mm x 1.0. I can sell you ones, exchange, already blocked, or I can sell you proper caps. The Cap'n |
ConeDodger |
May 29 2009, 10:54 AM
After nearly 20 years without a 914, I finally bought a daily driver (IMG:style_emoticons/default/driving.gif) It is a California spec '75 2.0 with original FI. I plan on pulling all the smog equipment as well as replacing the heat exchangers and muffler with SS exchangers and a Bursch exhaust. Just wondering if there is anything that will need to be plugged, rerouted, etc with these changes. Thanks! The air injection ports will have to be plugged. Some people just pinch off and braze the ports at the head. I have recently seen an ad in the back of Excellence or Pano for a threaded block off. I think they might be NPT but not sure of the size. Truthfully though, biggest bang for the buck is to backdate that exhaust system. The AIS pipes are 10mm x 1.0. I can sell you ones, exchange, already blocked, or I can sell you proper caps. The Cap'n There you go... I just did my own but now you have a source who supports the site. I suggest you support the member vendors. |
hcdmueller |
May 29 2009, 11:14 AM
????????????? Group: Members Posts: 542 Joined: 4-February 06 From: UK Member No.: 5,527 Region Association: England |
I changed my exhaust to SSI's and a Triad dual outlet. That was a HUGE improvement over stock. The engine ran smoother and cooler. It was the best money I spent before a 2056 kit from Jake.
poorsche914 |
May 29 2009, 12:00 PM
Lo-Fi Version | Time is now: 22nd May 2024 - 10:54 PM |
