Fuel line size |
Fuel line size |
ynotdd |
Mar 4 2004, 01:12 PM
Member Group: Members Posts: 156 Joined: 13-January 03 From: plainview, NY Member No.: 140 |
I am going to put a in line fuel gauge in.I am thinking of putting it near the adjustable fuel pressure unit.(stock FI) my question is what size is the fuel line there? I.D. ?Summit sells 1/2 and 3/8 fittings
help and thoughts please (IMG:style_emoticons/default/spank.gif) (IMG:style_emoticons/default/flag.gif) |
steve@ottosvenice.com |
Mar 4 2004, 01:17 PM
Member Group: Members Posts: 214 Joined: 9-November 03 Member No.: 1,324 |
8 mm Fuel line is used there. Steve
ynotdd |
Mar 4 2004, 01:23 PM
what does 8mm translate to 1/2 5/16 3/8 ?
JWest |
Mar 4 2004, 01:24 PM
Senior Member Group: Members Posts: 1,662 Joined: 6-January 03 From: Fort Worth, TX Member No.: 97 Region Association: None |
Very close to 5/16".
rhodyguy |
Mar 4 2004, 01:38 PM
Chimp Sanctuary NW. Check it out. Group: Members Posts: 22,093 Joined: 2-March 03 From: Orion's Bell. The BELL! Member No.: 378 Region Association: Galt's Gulch |
get metric.
kevin |
Chris H. |
Mar 4 2004, 01:44 PM
Senior Member Group: Members Posts: 4,032 Joined: 2-January 03 From: Chicago 'burbs Member No.: 73 Region Association: Upper MidWest |
Dave_Darling |
Mar 4 2004, 02:10 PM
The fittings, last I measured, were 7mm. I think 8mm would be a bit of a loose fit... I don't think metric fittings are necessary, particularly if you get barbed fittings. Which I would recommend. Do use the FI-style hose clamps, not the "regular" ones that slice up the hose as you crank them down.
--DD |
tod914 |
Mar 5 2004, 02:08 AM
Advanced Member Group: Members Posts: 3,755 Joined: 19-January 03 From: Lincoln Park, NJ Member No.: 170 |
7mm is a really really tight fit. That is what came stock on the car. 8mm fits nice. Much easier to get on and off. Try a local VW parts vendor or Foriegn supply place. Most will sell it. Make sure it is braided high pressure line.
lapuwali |
Mar 5 2004, 09:28 AM
Not another one! Group: Benefactors Posts: 4,526 Joined: 1-March 04 From: San Mateo, CA Member No.: 1,743 |
5/16" is only 0.002" smaller than 8mm, and a lot easier to find in the US. I'd venture that the manufacturing tolerances for fuel hose and barbed fittings are no better than 0.005", so they're basically the same. Indeed, I'd bet there's one factory making fuel hose that marks half the batch as 8mm, and the other half as 5/16".
Lo-Fi Version | Time is now: 10th June 2024 - 01:59 AM |
