| Project 6 |
Jun 23 2009, 09:19 AM
large member ![]() ![]() Group: Members Posts: 359 Joined: 30-December 02 From: Utah Member No.: 51 Region Association: None |
OK, so I'm ready to install the engine and found a surprise. The PO was going to install a later model trans. As such, they installed 915 style stub axles. The oem stubs are lost in space.
The existing stubs don't bolt up to the 914/4 axles and CVs I was going to use. The 2.0/6 "S" spec motor puts out about 140hp. So I wasn't worried about twisting them with high torque since I used this set up with a 3.0 in the past. My questions is....are 914/6 AXLES which I might have access to, compatible with 915 sized CVs? FYI 914/6 CVs have been NLA for 20+ years.... Since I have the sub axles, can easily find drive flanges for the trans, I was thinking this would be an easy alternative. Does the 914/6 axle have the same spline count? 28 is what I've been told. Simply using a 911 axle won't work, too long. Buying 914/6 stub axles is an expensive deal, $5-600. Mittelmotor and Otto.... Some good news, I HAVE been able to locate one stub axle...it will need a little machining as it's a bit corroded. But I'm looking for alternatives. Anyone BTDT? Or even better....an orphan 914/6 stubbie? |
| Dr Evil |
Jun 23 2009, 11:06 AM
Send me your transmission! ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 23,041 Joined: 21-November 03 From: Loveland, OH 45140 Member No.: 1,372 Region Association: MidAtlantic Region
Switch to regular /4 stubs and output flanges and use stock axles with CVs (IMG:style_emoticons/default/smile.gif)
| SLITS |
Jun 23 2009, 11:12 AM
"This Utah shit is HARSH!" ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Benefactors Posts: 13,602 Joined: 22-February 04 From: SoCal Mountains ... Member No.: 1,696 Region Association: None |
Ok Mike,
I have our axle supervisor looking to see if any of the early 911 CVs we have have the stub axles still attached. Most of the time they are removed. Will let you know ........... |
| pcar916 |
Jun 23 2009, 11:35 AM
Is that a Lola? ![]() ![]() ![]() Group: Members Posts: 1,524 Joined: 2-June 05 From: Little Rock, AR Member No.: 4,188 Region Association: None
914-6 axles are splined differently from the 4's, I have both. There are some good threads on this forum about the possible conversions. Look in the Lapuwali Classics section.
I was going to use 930 flanges inboard (930 CV's are easy to find and not terribly expensive) and 911 cv's outboard on the 914-6 axles, but I haven't yet been able to find early 911 flanges either. I thought they would make a good addition to my 3.6L conversion. I have stock 914-6 stub axles already installed. Although, I've used stock 914-4 axles and cv's with this motor for years without a problem. |
| Lavanaut |
Jun 23 2009, 12:34 PM
Hungry Mind : Thirsty Gullet ![]() ![]() ![]() Group: Members Posts: 916 Joined: 20-June 06 From: Bend, OR Member No.: 6,265 Region Association: Pacific Northwest |
I have our axle supervisor looking to see if any of the early 911 CVs we have have the stub axles still attached. Most of the time they are removed. After reading the original post a few times trying to understand the issue, it sounds to me like he's already got the 911 stub axles and tranny flanges. The issue is the 911 stubs won't mate to the stock 4-cylinder CVs (true), and the question is, will a 914-6 axle mate to 915 CVs? Right? I don't know the answer to that question. What I do know is that Sway-a-Way makes the axle you need if the 914-6 axle doesn't pan out. Of course if you can find another 914-6 stub, that's the easiest way to go. Reid |
| Lavanaut |
Jun 23 2009, 12:41 PM
I think this issue gets confusing because different people call the same part by different names. In my mind it's:
tranny <---> flange <---> cv <---> axle <---> cv <---> stub axle <---> hub no? |
| SirAndy |
Jun 23 2009, 12:42 PM
Resident German ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Admin Posts: 42,469 Joined: 21-January 03 From: Oakland, Kalifornia Member No.: 179 Region Association: Northern California |
Switch to regular /4 stubs and output flanges and use stock axles with CVs (IMG:style_emoticons/default/smile.gif) (IMG:style_emoticons/default/agree.gif) For a stock(ish) 2.0L /6, just go back to a /4 setup and sell off your current parts ... (IMG:style_emoticons/default/shades.gif) Andy |
| Joe Bob |
Jun 23 2009, 12:46 PM
Retired admin, banned a few times ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 17,427 Joined: 24-December 02 From: Boulder CO Member No.: 5 Region Association: None |
To use a 914/4 stub axle. You need a 914/4 hub. The /4 and /6 hubs are splined different.
Uing a 914/4 hub you'll need to machine and press in studs, you will most likely destroy the bearing. |
| Lavanaut |
Jun 23 2009, 12:50 PM
Switch to regular /4 stubs and output flanges and use stock axles with CVs (IMG:style_emoticons/default/smile.gif) (IMG:style_emoticons/default/agree.gif) For a stock(ish) 2.0L /6, just go back to a /4 setup and sell off your current parts ... (IMG:style_emoticons/default/shades.gif) Andy I'm missing something here guys, how you going to do 5-lug using /4 hubs? I'm assuming that's all part of the equation. Yes it can be done, but that's probably the least ideal approach. Again..maybe I'm just missing it. |
| Project 6 |
Jun 23 2009, 01:00 PM
What I have now.
tranny <---> flange <---> cv <---> axle <---> cv <---> stub axle <---> hub 914/6 <---> /4-/6 <---> /4s <--->/4s <---> /4s <---> late 915 <---> /6 Same thing uses big CVs /4 CVs and /6 CVs are the same diameter, the axles from the factory have different splines. /6 CVs are NLA. IF the splines on the /6 axle and the 911 axle are the same, I can use them. <---> The best scenario is finding another /6 stub axle....after going thru Krusty's pile of discards. We found one just hanging about on a file cabinet with three other 914/4 stub axles. |
| SirAndy |
Jun 23 2009, 01:08 PM
how you going to do 5-lug using /4 hubs? With a tool called a "drill" ... (IMG:style_emoticons/default/shades.gif) |
| Lavanaut |
Jun 23 2009, 01:13 PM
The best scenario is finding another /6 stub axle....after going thru Krusty's pile of discards. We found one just hanging about on a file cabinet with three other 914/4 stub axles. (IMG:style_emoticons/default/smilie_pokal.gif) how you going to do 5-lug using /4 hubs? With a tool called a "drill" ... (IMG:style_emoticons/default/shades.gif) That's your answer to "are 914/6 AXLES which I might have access to, compatible with 915 sized CVs?"...? Switch to 4-lug and drill for 5? Hmm. |
| SirAndy |
Jun 23 2009, 01:27 PM
That's your answer to "are 914/6 AXLES which I might have access to, compatible with 915 sized CVs?"...? Switch to 4-lug and drill for 5? Hmm. Yes. That's my answer. Do you have a better one??? 914/6 stuff is mighty expensive. Good luck finding a 914/6 stub axle. And if i read his post correctly, he has /4 CVs and /4 axle shafts that he's trying to mate to mixed/matched 911 parts. So yes, my answer still is to go to a /4 setup and sell off the 911 and /6 parts he already has. At least i'm trying to come up with a solution instead of just talking down people who are trying to help. |
| Project 6 |
Jun 23 2009, 01:35 PM
That's a question that's still hanging out there. I'm sure there are more than a few original six owners that have old axles with worn out NLA /6 CVs. What have THEY done? The easy answer is swap in /4 axles and CVs. They bolt right up to the existing /6 flanges and /6 stub axles. For those with original 6 transmission and rear swing arm assemblies that want a larger CV, the answer would be nice if the could use 915 CVs, which are larger and built to handle more HP. IF the spline count on the /6 axles arre the same as the 911 axles. Again, 911 axles can't be used, too long. Not MY problem but an interesting question. What's the spline count on a 914/6 original axle??????? |
| markb |
Jun 23 2009, 01:39 PM
914less :( ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 5,450 Joined: 22-January 03 From: Nipomo, CA Member No.: 180 Region Association: Central California
You're welcome to come up & dig thru our cv's.
| Dr Evil |
Jun 23 2009, 01:42 PM
Eric Shea sells drilled 5 lug hubs for like $100
| Project 6 |
Jun 23 2009, 01:47 PM
Again, all I'm missing at this point is ONE /6 stub axle.
Swapping the /6 hubs out, destroys the bearings. More money and my labor. Cheap, easy, no brains, time is my goal here. The /6 axle issue and bigger CVs is a seperate and distinct issue. |
| SirAndy |
Jun 23 2009, 01:56 PM
Again, all I'm missing at this point is ONE /6 stub axle. If that's the case, then all you need is $$$ (IMG:style_emoticons/default/biggrin.gif) |
| Lavanaut |
Jun 23 2009, 02:04 PM
Yes. That's my answer. Do you have a better one??? Yes, try to find another 914-6 stub axle if possible, and if that doesn't pan out look into Sway-a-Way axles as an alternative to 914-6. That was in my first post in this thread, maybe you glossed over it. I feel it's a better approach because he can use the beefier parts and doesn't have to use a tool called a "drill" to fundamentally reduce the integrity of his parts. And hey, sounds like he found a single 914-6 stub axle! If that's the case it's a non-issue in the end. (IMG:style_emoticons/default/cheer.gif) |
| SirAndy |
Jun 23 2009, 02:10 PM
and doesn't have to use a tool called a "drill" to fundamentally reduce the integrity of his parts. You got any real world data to back up that claim? If so, i'd like to see it ... (IMG:style_emoticons/default/shades.gif) Andy |
Lo-Fi Version | Time is now: 2nd April 2026 - 01:35 PM |
