sweet.pretty sure my "temp" 1.8 is a fresh rebuild |
Mueller |
Mar 5 2004, 05:18 PM
Picked up a 1.8 dirt cheap to throw in the car until my 2.0 is finished....upon looking at the motor (externally so far), it just dawned on me that it has been rebuilt...or it appears so...the black powdercoated fan housing and black powerdercoated intake tubes/plenum seem to point in that direction.....
also, when looking at the heads from the sparkplug access holes, the heads are amazingly clean........ this weekend I'll be replacing all the pushrod tube seals as well as the case/flywheel seals to play it safe leakage wise....... now the big question is do I throw my 1.8 L-jet FI on it or "convert" this one to use my extra Megasquirt???? (IMG:style_emoticons/default/smash.gif) |
type47 |
Mar 5 2004, 06:11 PM
Viermeister Group: Members Posts: 4,254 Joined: 7-August 03 From: Vienna, VA Member No.: 994 Region Association: MidAtlantic Region |
megasquirt so i could learn how to do it to my 1.8 (IMG:style_emoticons/default/laugh.gif)
GWN7 |
Mar 5 2004, 07:32 PM
King of Road Trips Group: Members Posts: 6,280 Joined: 31-December 02 From: Winnipeg, MB, Canada Member No.: 56 Region Association: Northstar Region |
Which way will get you back on the road faster?
fiid |
Mar 5 2004, 07:37 PM
Turbo Megasquirted Subaru Member Group: Members Posts: 2,827 Joined: 7-April 03 From: San Francisco, CA Member No.: 530 Region Association: Northern California |
If your L-jet is plug and play, then plug and play.
Otherwise I would MS. |
Mueller |
Mar 5 2004, 07:54 PM
it's a toss up to which one would be easier....if you've seen my garage finding all of the L-Jet parts will be "challanging", LOL
actually, from the looks of the new motor, all i need is the dual relay and the AFM which I know i have, I just hope I have the hose that goes from the AFM to the throttle body..that is not an item I'd want to buy........ |
Lo-Fi Version | Time is now: 9th June 2024 - 10:20 PM |
